Question about Canon PIXMA MP210 InkJet Printer
PAPER WILL NOT GO IN STRAIGHT AND THEN SAYS PAPER JAM AND THERES NO PAPER IN IT TO BE JAM
  • 4,041 Answers
Hello there
You may not see a paper jam.
There may be some thing there.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
Touch2Heaven
  • 145 Answers
SOURCE: false paper jam
check front and rear paper sensors. Maybe they damaged. Clean optical sensors.
Posted on Nov 17, 2008
SOURCE: Kodak ESP 7 jam paper...but theres no paper...
I had the same problem, but after pressing the OK button and when the paper jam came up again I pressed the CANCEL button and was able to print my document.
Posted on Apr 12, 2009
  • 214 Answers
SOURCE: printer keeps telling me that theres a paper jam but theres not
A small piece of paper is probably covering a sensor. Get a torch and dive in there.. have a good look
Posted on Apr 24, 2009
Ajkill
  • 2035 Answers
SOURCE: lexmark x6170 paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 03, 2009
  • 13433 Answers
SOURCE: paper jam
go over these steps:
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
MY PRINTER SAYS PAPER JAM BUT I CHECK NO PAPER JAM WHAT DO I DO
find the paper jam xD haha check the sensors make sure none are broken or stuck and again theres always the possibility theres a torn piece of paper in it
Apr 22, 2014 | Kyocera Office Equipment & Supplies
Paper jam error with my canon mp180 printer and it wont let me do anything i have checked the printer numerous times to see if theres anything in there and theres not.
This problem can occur, may be there is no paper jam inside but improperly inserted paper in the paper tray.
Check and verify that there is no paper or a piece of paper stuck in the roller or the belt. Remove all the paper from the paper tray and insert them again, do not fill the paper tray fully,
Aug 24, 2011 | Canon PIXMA MP180 All-In-One InkJet...
Hp laserjet 2015 printer shows an indicator light error that theres a paper jam but actually no paper jam or paper particles . I have cleaned aii the sensors and checked the paper path. Powers on well...
restart it
if problems insist check if sensors are working
if are working you need to replace motherboard
of your printer that cost to high
you better replace your printer
hope i had help you
Nov 26, 2010 | HP LaserJet P2015 Printer
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Won't let me fax, copy or print. it tells me paper jam 2 look in
paper jam 2 generally denotes the fuser unit. thats at the back, the bit that heats up, theres a flip up/down cover that once opened should show you if theres any paper in there, also check the sensor, little black arm, move freely and be sprung, if the sensor is missaligned it will denote a paper jam even when there is none be careful to let the fuser cool down, printer unplugged for 10 minutes or so, 180 degrees will hurt.
Sep 24, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Printer keeps telling me that theres a paper jam but theres not
Apr 23, 2009 | HP Officejet 4315 All-in-One Printer
Mar 23, 2009 | Office Equipment & Supplies
False paper jam
Nov 17, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Imaginary paper jam
theres a paper jam back door in the back of the printer open that up see if theres papers there or something like hair or bug
May 30, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP210 InkJet Printer Logo
179 people viewed this question
old marine
old marine
