Question about HP Officejet 6310 All-In-One InkJet Printer
Out of paper message
The paper is drawn into the printer unevenly causing it to jam before actually loading. The print is slanting downward from left to right. Sometimes the printer draws the paper back in after it is printed causing another jam. When the feed and release features are working, the printer is fine.
    Novelist:
  • 141 Answers
It sounds like the roller in the back, clean it with a soft rag with a little bit of alcohol. I had the same problem and ended up throwing it away and bought a Kodak 5300. Did you try going to HP solutions center? Good luck.
Posted on Mar 26, 2008
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
Whenever I go to print something, my printer makes a really loud grinding noise and occasionally jams paper. What could it be?
It can be that the paper drawing mechanism of the roller and the geared drive has an issue, possible that the motor has a play with the roller out of alignment , producing a difference of gap in the roller settings. If so the paper will be drawn into in different lengths so as to jam with the uneven pulling.
Sep 28, 2010 | Dell 1720dn Laser Printer
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
My printing result slants to the left. how can i resolve this? did maintenance on control panel but does not work.
its very simple dude...!!!!
if your paper feed tray is at the back...
just put your hand into the paper feed tray and you can feel a small roller which rotates very easily.....
just turn it anti-clockwise(it is unidirectional-turns only one way) adjust it a little and print something white and notice if the paper is drawn in slant...!!!
Sep 05, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam problem
Remove the back cover and put an index card thru where the paper goes, that should push out any left over scraps.
Jul 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Just bought the product and it is already not working.
Check the paper setting in tray. May be slanted and causing it to pull paper in un-even, this will cause jams. Old, wrinkled paper will also cause same problems.
Feb 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper Jam HP LaserJet 1020
Papper never realy "jams" the problene is usualy that the paper is late reaching the next paper sensor. What i would sugest is that you clean the paper pickup roller it is usualy in the shape of a D. Clean it with dishwassing soap dont use water just clean soap rub it on with a clean cloth until the roller is dry so use a small amount. This should solve your prbleme.
Apr 23, 2008 | HP LaserJet 1020 Printer
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Paper jam Brother MFC-215C
Norman,
does the printhead run smoothly to the left side of the printer when it is powered on?
If the printhead cant run that freely, it will give you the paperjam message. You have to dismantle the printer again, connect the scanner and cables again when top cover is removed. Press the scanner open contact (opposite to the menu button) and watch the printhead run to the left side. It might be that either the printhead stucks somewhere on its way (press the cover of the printhead. It might be the reason) or the guide rail hinders the printhead to move.
Oct 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
87 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
