Question about Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range
My Kenmore oven won't work there is a PF 5AB error
My Kenmore range oven won't work there is a PF 5AB error displaying on the control panel. I've tried unplugging it and plugging it back in to no avail. The burners are working.
  • 15,935 Answers
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
What does the code PF 5Ab mean for a Kenmore range, model # 665.75132300?
It sounds like the oven control board may be faulty. Go to this site and submit your stove model for further information on this problem.
Dec 15, 2014 | Televison & Video
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have a code 5ab on the panel my model nuber is MGR5775QDS its a 30 inch free standing gas stove.
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2348-maytag-oven-weird-error-code-5ab.html#ixzz1GLM0d1gp
Mar 12, 2011 | Maytag MGR5775QDS Dual Fuel (Electric and...
We have a Kenmore electric range mod. C970-440732. We have 5b or 56 error code on each element display control and 5ab error code on temp display on the the control panel. Nothing work except the clock. ...
Sorry to read about your problem, I hope this helps you out.
I am going to assume it a F5 error code, which means your have a oven control failure. and may need replacement. electronic oven control (also called EOC or clock).
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Kenmore Ovens
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range Logo
1,306 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
