Question about Toshiba e-Studio DP170F Plain Paper Laser Fax
Fax error status NG B0
What does Fax error status NG B0 mean?
marsrover
  • 682 Answers
SOURCE: When transmitting a fax the
there is a noise or static in your phone line try to put line phone filter from radio shack(279-151)-otherwise contact phone company.
Posted on Aug 03, 2008
ziraffa
  • 827 Answers
SOURCE: OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Posted on Dec 21, 2008
leroyal
  • 2120 Answers
SOURCE: What does 'NG' mean on the fax activity report
NO GOOD (USA) or NOT GOOD (ASIA)
Posted on Jan 21, 2009
FixinFax
  • 3085 Answers
SOURCE: Fax doesn't go thru, on the TX Failure report
No Good, receiving machine never answered.
Posted on Jul 04, 2009
FixinFax
  • 3085 Answers
SOURCE: Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Posted on Oct 07, 2009
Toshiba DP 125F What do these status codes mean: a)NG B0 b)50 Also how do I fax to a long-distance number if adding long distance code?
If you mean by "50", Device Error 50, make sure the cable is firmly connected between the main motor and the Mother PBA (CN3), between the Mother PBA (CN24) and the Main PBA (CN12). Otherwise, replace in this order:
1. Main motor.
2. Main PBA
3. Mother PBA.
Jan 12, 2011 | Toshiba DP125F All-In-One Laser Printer
What does NGB0 mean on the activity report?
NG is shortcut for "No Good", indicating a problem. "B0" is the fault code for a communication problem, usually caused by an incompatible setting of communication mode G2 or G4 on the remote machine.
Contact the remote operator and ask he set up his machine for EECM or G3 communication mode, then retry.
Jan 06, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
I am trying to receive a 46 page document but I am only getting some of it. The first attempt resulted in me receiving 5 pages and the second attemp resulted in only 2 pages. I have checked the log for the...
If you are not getting any kind a jam indication on your end then it is most likely a phone line noise issue causing the transmission to fail. One thing you can try is turn off the ECM setting on your machine. This stands for error correction mode. If you have your manual you should find it there. ECM is the cause for most failures of the type you are describing.
Oct 21, 2009 | Canon Office Equipment & Supplies
Oct 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Activity Report Codes
NG means "no good". it means your fax didn't go through correctly or wasn't received correctly. ie wrong number of pages etc.
Apr 29, 2008 | MinoltaFax 2600 Printer
Cannot Send Faxes
Problem:
Not sending to long distance and government sites with encyrptor. Note: NG is not actually part of the Fault Code. NG stands for No Good on the Activity Report. Cause:
Not enough time to hand shake. Another cause of B5 can be a faulty Main PWB. Note: Should you wish to change the Main PWB, consult the following ETI 170535 to insure that you are selecting the correct part number. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. On speed dials and one touch numbers that the Customer is having problems with, you will have to modify the number to be dialed. What you have to do is add pauses to the end of the number. (example 555-5555 does not send to, error B0 (that is B Zero ) every time / then start adding pauses at the end of it until it works. Example 555-5555#. in some cases in Winnipeg and surrounding areas we have had to put up to 6 pauses to get a successful send. Note 1: These were to Fax Machines with encryptor devices and long distance...Avoid Call Backs. Inform the Customer of this. LEAVE instructions on how to do this. This will save your and your Customer some headaches. Note 2: Some success has been found by turning off the V34 Modem
Apr 16, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Confirmation Sheet
It means that the fax was not received without errors. In other words No Good. Not that it literally means that, but all fax techs call it that.
Mar 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Sending fax
NG STANDS FOR NOT GONE , TYPICALLY THIS MEANS THAT THERE IS A COOMMUNICTION ERROR AND THERE IS ALINE DISTURBANCE /NOISE DURING THE CONNECTION WHILE SENDING THE FAX MESSAGE. TRY CHANGING THE TELEPHONE LINE IF IT IS AVAILABLE. HAPPY FAXING OMNIPRESENT
Oct 02, 2007 | Brother IntelliFAX 4100 Laser Fax
Toshiba e-Studio DP170F Plain Paper Laser Fax Logo
509 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
