Question about Compaq Presario M2000 Notebook
M2000 heat causing trouble?
I recently noticed my M2000 getting extremely hot, as in so hot it hurts to touch. The fan seems to work sometimes, but now it will randomly refuse to boot up, and it constantly locks up.
Sometimes it will lock up before anything even finishes loading in Windows, sometimes it will take a few minutes then do it. I have tried it in Safe Mode and it still EVENTUALLY locks up every time. The longest I have been able to use it before it freezes is 5 minutes.
Any ideas?
Same thing happend to me, order another cooling fan. use some other house fan to cool off the computer. jus set it next to it with the wind towards the keyboard. it should start up and stay cool with the fan as a manaul way to cool it so it doesnt shut off
Posted on Mar 31, 2008
  • 46 Answers
Are the fans clear from dust and debris? this is a major factor, if it keeps freezing you may have partially burnt out the processor or other component.
Posted on Mar 26, 2008
SOURCE:
What would cause hose from pump to tank on a porter cable pancake comressor get extremely hot when running
It is normal for the line going from the compressor to the tank to get very hot in all air compressors. Compressing air creates allot of heat. It will get hot enough to cause burns if touched.
Nov 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
We have recently noticed that the part of the refrigerator that separates the freezer from the refrigerator is very hot to the touch on the Samsung RS2630WW Side by Side Refrigerator. It also seems hot on...
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 inch section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
[email protected]
Sep 09, 2010 | Samsung RS2630WW Side by Side Refrigerator
Recently the transmission in my 94 Mitsubishi Diamante overheated and mysteriously died. I hired a shop to rebuild it. The shop rebuild the transmission and i picked the car up. On the way from the Auto...
The only thing I can think of is clogged up cooler(transmission fluid cooler) , on some cars it is part of radiator , on the others it's separate small radiator.
Hope it helps.
Jun 22, 2010 | 1994 Mitsubishi Diamante
Since recently i notice am hearing the sound of the fan on the laptop spinning louder than usual. the computer these days is very hot all over. the heat that comes off it is extremely hot.
i think ur system fan cable need resolder. for this it cann't run freely or the other things for many dust in ur fan it can run freely. so check these if everything are ok then plz change ur system fan. u computer shut down bcoz when ur processor doesn't get sufficiant air then it become so hot and ur pc will off. its so dangerious.
Aug 08, 2009 | Everex StepNote XT5000T Notebook
My whirlpool side-by-side is getting hot on strip between doors but everything seems to be working fine. Is there a solution? What if it becomes extremely hot??
It will not become extremely hot. It is heated by a thing called a mullion heater. It warms the area so it doesn't sweat and mold in the summertime. It is perfectly normal.
May 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore fridge not getting cold
first thing to heck would be the condenser fan motor which is located int the compressor compartment pull the refrig away form the wall remove cardboard cover and inspect the fan motor that you will see. check for obstruction or if the fan motor is seized. if this motor fails it will cause the compressor to run extremely hot then shut off on internal motor protector. if you determine the motor is bad you can place a house fan behind unit blowing on compressor area to keep unit working until you get it repaired.
Thanks Peyton
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Radiator fan for honda civic 1988 not switching on
there is a temp switch located on the radiator ..with a quick realease plug..replace the switch or get the old switch from the old rad and try it. be careful..keep the cabin fan on full hot to relieve heat off the engine..and top upp coolant.
Dec 06, 2008 | 1988 Honda Prelude
Heat /air fan
Lose wire or ur switch is bad take it to a shop and get itr looked at Looking Forward to helping u Shaun
Nov 15, 2008 | 1994 Buick LeSabre
Maytag refrigerator MSD2758GEW divider panel hot to touch
What you could check is that the fan at the back of the unit, where the compressor is located, is working, as this could also cause a heat build up. The partition between the two sides does generally tend to get hot due to the door circuit, to prevent ice buildup around the door. But people tend to notice when something is different. You are also right to check for dust underneath the cabinet as the condenser tends to be layered. If you have already cleaned it all out then you have probably done as much as you can. If you are still concerned contact a fridge guy. Hope this is of some help.
Sep 12, 2007 | Maytag MSD2758GEW
Compaq Presario M2000 Notebook Logo
101 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
