Question about SNK Fratelli Onofri Royal Chiantishire FRRYC905DBLBR Dual Fuel Range
I have just purchased a Fratelli Onofri Evolution range/oven. Eveything works but the oven fan makes a grinding noise. How can i fix this problem?
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
buffalonyman
  • 1865 Answers
SOURCE: A Kenmore and GE gas range have recently been
New Ovens may give off an odor, but it will cease after a couple uses
Posted on Apr 24, 2009
SOURCE: Oven only works when one of the range burners is on.
It might be a gas valve. Pretty unusual problem.
Amana oven repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: my ge xl44 gas range
Probably just a weak ignitor. Fairly common on these. If you can change a spark lug you can change an ignitor.. These get weak and dim. if yours comes on but is dim orange it is weak and not allowing the bi-metal to open. If yall bump the stove and the oven comes on that is another sign of a worn out ignitor:
GE XL-44 stove service manual
How it works: Silicone carbide ignition
A tip by TheMobilian
Posted on Apr 21, 2011
  • 4736 Answers
SOURCE: i just installed a new
The first thing to check is the required, inline gas shutoff valve. Is it fully ON. I know it had to be turned off to complete the conversion to LP Gas.Secondly, if you had a convertible gas regulator, was the little pin reinstalled in the proper direction. If you didn't have a convertible gas regulator, are you sure the one you changed to, is in fact for LP Gas? If not, there would be little to no gas flow. As Natural gas requires a different pressure than Propane Gas.
In addition, there may be air in the line, from when the gas was turned OFF. That air will need to be purged from the line. You can do this, by trying to continually light a burner. If after 5 minutes there's no gas. The problem may lie in an obstruction in the gas line. Check for any trash (pieces of Teflon tape, Pipe Joint Compound, etc) in the line to the cook top.
Also, if you have the equipment to do so. Check the water column inch after the regulator. It should be 11 to 13 water column inches for Propane & 7 for Natural Gas. If you don't have the equipment, contact your Propane Provider as they do have it.
Hope this helped you to further troubleshoot and solve the problem Please let me know. Thanks.
Posted on Jun 13, 2011
Has anyone had any luck finding replacement gasket? I have a Italian-made Fratelli Onofri 36"range (FREV 905S) and need to replace the oven gasket, which is broken.
Hello, Camr -
You did not state where you reside (what country.) Knowing that information will help in providing you the best source for a replacement oven door gasket.
In case you reside in the United Kingdom, you will find a replacement gasket here:
https://www.espares.co.uk/search/ma2925pt1602/cookers-and-hobs/seals/fratelli-onofri
Best wishes.
Mar 13, 2018 | Kitchen Ranges
I need a conversion kit natural gas to propane for a Fratelli Onofri range. Anyone handle parts for these in the States?
try your local propane dealer .some newer stoves do not require a kit ,as they have adjustable orifices
Aug 13, 2015 | Kitchen Ranges
Royal chiantishire buzzing how to fix
I have the same buzzing ticking clock sound much too noisy. Can't find a way to get to the clock
Mar 19, 2014 | SNK Fratelli Onofri Royal Chiantishire...
Oven does not get hot in bake mode
1st do you smell gas?
2nd if so, you're igniter isnt working, call for service, to your oven DO NOT play with gas, it can kill you
Sep 29, 2012 | Bosch Evolution HGS715 Kitchen Range
Handle loose on fratelli onofri royal chiantishire range
take off the whole door including the glass and possibly the lower shelf watch out for screws inside you can fix
Jun 19, 2012 | SNK Fratelli Onofri Royal Chiantishire...
My ge xl44 gas range ..all of a sudden the oven does not work...eveything else does... do i need someone to come out? HELP...
Apr 21, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
SNK Fratelli Evolution FREV905S-S Stainless Steel electonic clock and timer running slowly
This is from Tim at JMAppliances 2/24/2011:
These clocks are built to operate at 50 cycles(Europe) and 60 cycles(USA) and this is controlled by the audible alarm setting. The clock has to be set on the loudest (highest tone) alarm for the clock to operate at the correct setting. You control the loudness of the alarm by pushing the minus button (second from the right) repeatedly until you here the loudest (highest) sounding tone. Leave it at that setting and the clock will work fine.
Hope this helps
Feb 09, 2010 | SNK Fratelli Evolution FREV905S-S ...
SNK Fratelli Onofri Royal Chiantishire FRRYC905DBLBR  Dual Fuel  Range Logo
57 people viewed this question
Top SNK Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a SNK Kitchen Range Expert? Answer questions, earn points and help others
