Question about Tandberg Data 220LTO LTO 1 Tape Drive
Remove stuck tape
How do I manually remove a tape stuck in the drive?
The only other thing I would add, is that you have to turn the eject screw about a zillion times to get it out. Way more than you would think.
Posted on Oct 31, 2008
It depends on the type of TD you are using. For many TDs, there is a manual eject screw, either on the bottom or side of the drive. You can usually access this screw without removing the cover or faceplate (although side mounting rails may need to come off). The manual ejection screw is usually recessed a little bit, and may even be covered by a piece of clear plastic (in the case of DDS 4-5 drives). It will also have an arrow indicating which way to turn to load or unload. There are usually standards within each seperate TD technology - but there is no standard across all tape drives - and Tandberg as a company is notorious for not having one at all. DDS 4 and 5 for instance - the screw is on the right side of the drive, near the rear, turning the screw clockwise will unload the media.
For a Tandberg LTO2 drive, there is no way to remove the media without removing the top cover and essentially rendering the drive unusable. If your drive or server is under warranty with onsite support - that would be the best option for a Tandberg LTO2 drive
Posted on Jul 21, 2008
5 Suggested Answers
SOURCE: Stuck Tape Removal
with only te power connected, press the eject button for approx 10 seconds. The drive will reboot and hopefully eject the tape.
Posted on Aug 01, 2008
JaxPlanet
  • 921 Answers
SOURCE: ultrium tape stuck
I highly recommend that you contact Certance for assistance. Tape drives are expensive and you don't want to risk damaging it.
If you are feeling brave you could see if you can manually eject the tape.
Remove the tape drive from the chassis and look for a manual rewind screw on the bottom or back of the drive. This is provided on some drives to allow you to manually wind the tape back into the cartrige and eject it.
I hope this helps.
Posted on Aug 11, 2009
  • 74 Answers
SOURCE: Hi I need to manually remove a tape from a quantum
Hi Adrian
I would suggest sending it to www.tape-drive-repair.com for them to fix as once the tape has been removed you will still probably have the original fault that caused the tape to get stuck.
If you do try and remove the tape yourself be extremely careful as those drives are very easy to break the load mech and tape leader assy if you dont know exactly how to remove them.
Bear in mind the tape may not actually be stuck though!
Try powering off and on the loader with it disconnected from the server just in case it is your backup software not letting the drive eject the media as this is a common issue (where the software tells the drive it is using the tape (or hasnt finished with it) and stops the eject button from accidental operation)
Posted on Aug 24, 2009
SOURCE: tape cartridge seems stuck in the my tandberg LTO2
I had the same issue with my drive. I presume that you have tried holding down the eject button while powering on the drive. If you have done this and it didn't work, I have a PDF from Dell that describes how to manually remove a stuck tape from this drive. I would not recommend it for anyone who is not very technical. It is a little complicated. If you would like a copy of it, you can send me an email at my hotmail.com email. It is tm_reply at hotmail.com. Since the PDF does not have the directions to re-assemble the drive, you need to pay close attention to the way things are while taking it apart.
If you are not comfortable sending me an email, you can go to Dell's support an do an online chat. Ask them for the doc. That is where I got it. He emailed it to me so that is why I don't have a link.
I do have a link for the full height drive. it is - http://support.dell.com/support/edocs/stor-sys/110TL_Ce/en/index.htm
Thanks
Todd
P.S. If someone can tell me how to post a file here, I would be happy to do so.
Posted on Jan 04, 2010
How to remove stuck tape
To type over the 3 pages from the manual and put the two images here, would be to much. Every DLT and Ultra SDLT manual has a chapter about how to remove the tape, when it got stuck. Please use your own manual for this.
Aug 06, 2014 | Ultra SDLT 600 (000004679226) Tape Drive
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
Feb 27, 2014 | Mitsubishi Televison & Video
Small motorla color tv vhs tape is stuck in tv
Remove power to the set - unplug the wall outlet. Remove the screws that attach the back cover. Remove the cover. Remove the cables that connect to the VHS drive to the TV main board. Remove the mounting screws that attaches the VHS drive to the set. Remove the VHS drive. Manually turn the take-up gear which is near a motor to allow the tape to mechanically eject the tape - do not force.
Feb 19, 2011 | Televison & Video
I have hp surestore DLT1e drive. Tape cartridge stuck!
For that you can try to press and hold the eject buttonfor 30 seconds if the tape doesn't came out then reflash the drive firmware revision.
After all that is the issue persists you can try to:
manually remove the tape by removing the top cover
Locate recessed thumb wheel
Rotate thumb wheel counter-clockwise until you feel resistance. Wheel may spring back when you release it. This is OK.
Locate hole in bottom of drive. Insert #10 Torx driver and rotate clockwise until tape ejects. If there is a lot of tape on the take up reel, this could take some time.
Rotate thumb wheel clockwise to eject the tape.
Apr 08, 2010 | HP Computers & Internet
I have a tape stuck in my drive and I can't eject it either on the hardware or using back up exec. The folloing lights are on Green power is on, orange status is on, and red error is flashing Any ideas how...
The only option for you is to remove the tape drive from your server, open it, and manually eject the tape that is stuck. This is not easy to do. Maybe it would be better if you remove the tape drive from the server and take it to a repair centre.
Oct 26, 2009 | Dell Computers & Internet
Hi I need to manually remove a tape from a quantum 3 superloader. The tape appears to be stuck in the drive
Hi Adrian
Aug 17, 2009 | Quantum LTO-3 (BHWCXEY) LTO-3 Tape Drive
There is a tape stuck in the LTO 3582-L23, how to takeout manually?
Its not easy to remove the stuck tape as it require you to
1. Remove the sled from the library
2. Remove the drive from the Sled.
3. The Drive Part would be more complicated.
I sugguest you send it to a tape drive repair centre and let them service it for you.
You can try sanwork.com
Dec 02, 2008 | IBM TotalStorage 3582L23 (18P9522) Ultrium...
Ultrium tape stuck
I hope this helps.
Jul 25, 2008 | Certance (CL1001-R) Ultrium Tape Drive
Stuck Tape Removal
usually a reboot gets it out...hit eject button BEFORE windows starts up...I've seen some get stuck forever... Good luck.
Aug 22, 2007 | Quantum ValueLoader SDLT 320 Super DLT...
Tandberg Data 220LTO LTO 1 Tape Drive Logo
1,436 people viewed this question
Top Tandberg Data Computers & Internet Experts
David Payne
David Payne
Are you a Tandberg Data Computer and Internet Expert? Answer questions, earn points and help others
