Question about Echo Rapid Loader, Trimmer Head
Starts easy will not rev up - Echo Rapid Loader, Trimmer Head
  • Echo Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
Free lander rev counter intermittent and eng light on and off
What's the color of the smoke? white, white with a blueish color, or black?
Dec 01, 2015 | Cars & Trucks
2002 sebring sudddenly will not rev over 1500 rpm
start car, try to rev (try to cause error)... allow to idle for 30 secs
shut off car, with car stopped, turn key, on-off-on-off-leave on. codes will be displayed in odometer readout.
if code P0340 it is the cam sensor, very easy fix, one bolt.
Apr 16, 2012 | 2002 Chrysler Sebring
When my buick century 1995 is cold it will start but won't rev up. once it is hot it runs okay
Number of possibilities. See if you have any diagnostic codes stored. Could be throttle position sensor, coolant temp. sensor, hard to say. I would start with the codes. Does it start easy when warmed up, and run good? Boy, I just don't know.
Oct 30, 2011 | 1995 Buick Century
It's a 1993 and it starts idles revs fine. But when u put it in gear it bogs down. Is it jettig or air or what?
First place I'd check is the carbs - make sure the choke isn't engaged!
Choke on = easy start + easy idle + easy revs + bog under load.
Too much air (hole in the airbox, hose off the airbox) can do this too.
Apr 09, 2011 | kawasaki KX 125 Motorcycles
I have a 2004 Chevy Malibu. Bogs down and stalls with acceleration. Check engine light flashes. Idols fine. Changed the MAP as it had a P0101 code along with the P0300. Changed the plugs 3 weeks ago and...
make sure you have ngk or ac delco iridium plugs installed. Also common problem on the 2.2L ecotec is the cat plugging. Easy check is to remove the front o2 sensor (very easy 22mm wrench) and start the car and rev it. If it revs freely now and does not bog the cat is plugged. They are covered fed. emissions warranty 8yr 80k, all gm dealers stock the cats for the 2.2 ecotec.
Mar 14, 2009 | 2004 Chevrolet Malibu
Automatic choke stopped working- difficulty start- revs dropping low at stop
Quick and easy attempt to fix might be to try some fuel injector cleaner,the purple bottle stuff I put in, is only about $3 a bottle, and seems to eliminate similiar symptoms brought on by bad gas.
Jun 12, 2008 | 1990 Honda Accord
Echo Rapid Loader, Trimmer Head Logo
285 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
