Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer- F21 error code. Tub not draining
  • 3 more comments
  • Anonymous Apr 02, 2008
    flashes F-21 during rinse cycle, won't run the fabric softener unless you run it on rinse and spin cycle 1+ times. Door will not unlock
  • Anonymous Apr 05, 2008
    error code F2 is blinking and the washer does not spend. The clothes are very wet when the cycle is done.
  • Anonymous May 04, 2008
    Washer will not drain - f21 code. I have verified that the drain is clear as well as the hose into the drain. Quite annoying given washer is 14months old and barely beyond warranty.
  • Anonymous May 05, 2008
    Tub not draining. Machine is less than 5 months old. Checked hoses/set-up as indicated by manual in regards to F21 error code. No problems noted. Have emptied the tub manually and tried the drain/spin cycle but still didn't drain.
  • easpice Mar 21, 2009
    Washer is almost 3 years old. Got the dreaded F21 error last night. Took hoses off, nothing clogged. Ran diagnostics and still get the F21. Wonder if it is the pump?
Will not spin or drain and f21 shows up
Posted on Sep 26, 2008
6ya staff
SOURCE:
My whirlpool duet front load washer is giving a F21 error code. It will not drain. When I blow into the drain hose on the back of the washer it will start draining. But everytime I run a new cycle it will...
whirlpool duet front load washer this video is on a bosch but it will help you Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool duet front loader and when my washer get to the last 2 minutes it Flases F. What is this and how do I fix it???
This is a fault code but the F flashes alternately with a number or another character depending on the model of the machine to indicate the fault code number. Since the fault happened at the last two minutes of the cycle, it is likely associated with a drain problem and the fault code is likely F02 or F21 depending on the machine's model.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, you'll find a knob which is the drain filter. Turn the knob counterclockwise to remove the filter and clean it. You may need to lay a towel under the filter to catch residual water before removing it. Manually drain the water, by gravity, from the tub if significant amount of water is still present by placing the end of the drain hose as low as possible into a basin or bucket.
Click on the link below if cleaning the drain filter doesn't solve the problem.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washers
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Take care
May 31, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet will not drain, F21 error code
YOUR "DRAIN MOTOR PUMP" is clogged with all that rubber particules, if your handy with tools , you can fix this one , open the washer , locate the MOTOR PUMP , (just follow where the drain hose is connected), remove , inspect and clean all the debris and lints and stuff collected , replaced and youre good to go , AJ
May 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,172 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
