Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Small engine on mower will not start with air filter but will without and will stay running after reinstalling filter.
Clean or install new spark plug. Mine does the same thing
Posted on May 05, 2010
  • 349 Answers
Have you replace filter or cleaned it it may be dirty not allowing you to crank it with it on.
Craftsman 22" self propelled platinum series lawnmower died while pushing it. wont restart. ????
A good place to start is taking the air filter off. Then try stArtingvit again. Often a dirty air filter will not allow a mower to stay running. If that does not help. Remove the cover under the carburetor looking for dirt in the cover. Also well the cover is off remover the small pin that holds the float in place. Pull the neddle valve out cleaning it and the other parts with a carburetor cleaner then reassemble
Jul 21, 2014 | Briggs & Stratton Garden
Toro lawn mower troubleshooting
Clean the carb, gas tank and fuel line (s). Replace air filter with a new one, I wouldn't recommend that you run it without the filter because that allows dirt and grass debri to enter the carb, fuel line and gas tank.
Replace the plug with a new one that is recommended for your engine.
Check oil level.
Other option is lawn mower repair shop....
Hope this helps, I had the same problem.
May 11, 2013 | Garden
Craftsman mower with 6.75 B&S motor will start and run fine for about 3-4 minutes and then slowly chokes out. I cleaned the air filter and need to know what to check next. Thanks.
hi there
though you have cleaned the filter it could still be not getting enough air you can start the machine without it and see if stays running do not do work with it just see if it runs sitting there if it does simple fix new filter however if it does the same it is a lack of fuel either fuel filter if has one if not it will be in the carburater these get gumed up by old gas in which in that case find a small engine repair shop to take care of this issue
thank you for the question hope i helped with the issue good luck and have a great day
Aug 20, 2011 | Briggs 491588 and Stratton Original Air...
Have gts toro, engine starts then stops can not get it started.. r s
Your mower engine has to have these things WORKING to run: 1. Compression (engine in good shape) 2. Strong Spark (magneto air gap has to be correct for strong spark) 3. Clean air ( good, clean air filter w/no air leaks) 4. Clean, fresh fuel supply (gas less than 30 days olds with an inline filter installed in mower's fuel line). These things are assuming the mower hasn't struck an immovable object such as concrete, tree stump etc. recently. This will shear the flywheel key and timing may be off so far that engine won't start. So, where would you like to start my friend? Try checking these things. In the meanwhile....we can try to "coax" the engine into running. Remove the spark plug. Get an aerosol can of carb/choke cleaner spray. Spray a couple of shots into the engine. Reinstall plug. Choke the carb and attempt to start. This may or may not work, according to the conditions listed earlier. If this doesn't get it running, remove the plug and try it again.
We are trying to get it to run on its own, so it will start (or attempt to start) drawing fuel from the carburetor. Sometimes the brass bolt that holds the carburetor float bowl on gets clogged. You drain the gas, remove the bolt and clean all the small hole in the bottom and along the sides of it. This bolt is also the main jet of the carb. Cleaning this with carb cleaner can only help. If you do this, use NO metal objects to poke or scrape the bolt. The holes are metered and have to stay that way. Check for spark, check your air filter, see if the plug gets wet after you attempt to start. If it doesn't get wet or even smell like gas, then likely you have a fuel flow problem. Try ALL these things and post back; and again, if you have hit something solid recently with the mower, you will have the replace the flywheel shear key. It is a small aluminum $1.00 part so don't worry. Post back as needed. We wish to help.
Jun 19, 2011 | Toro Lawn Mower With Toro Power Tools
New plug will not turn over prime and still will not turn over or run
Jun 19, 2011 | Toro Power Lawn Mower
Engine starts but immediately stops
Engine starts but stalls out. Plug cleaned and air filter removed.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
"Poulan" Push Mower: the mower will start but not stay running...
Have you checked the spark plug to see if it is fouled? If thats not it, maybe the air filter is clogged. If that still isnt the case try some B-12 small engines carb cleaner. Use it generously.
May 17, 2010 | Poulan "Poulan" Push Mower
My mower starts and stays running for about 5 seconds then quits..has gas and oil any clues
Check gas line. Check for a gas filter and replace it. Replace spark plug. If the prob continues - it might need the carb rebuilt.. If a small engine sits to long without being run - the gas will shellac in the carb and render it to not function properly..
have a great day !
Apr 09, 2010 | Mtd 22" Yard Machine Push Mower
Engin will not stay running dies
No fuel filter but there is the air filter. Try removing the air filter and starting the mower. If this works replace the air filter. If not, then check the engine's carb. Engine was made by Tecumseh. There aren't many parts to a Tecumseh carb so replacing the few parts (gasket around bowl, float, needle and seat) isn't a lot of trouble.
Jun 13, 2009 | Garden
I have a troy built self propelled mower, it ran great last season, now it will not stay running. I checked to see if it was getting fuel and it is. I primed it and it acts like it is going to run and then...
The jets in carbs are really small and clog easily. If you stored your mower with gas in it start by replacing the gas. Remove the air filter and prime the carb. Start the engine and place your fingers over the air intake on the carb. This will cause the engine to stall as it will be starved for air. It will also create a powerful suction on the jets and possibly dislodge a blockage. Prime the engine again and start. If does not continue to run, repeat the steps again. If after 3-4 tries your engine wont run you will have to remove the carb and clean the jets manually. The reason your engine runs for a short time is because it is burning the fuel that you put in there by priming it. After that the fuel comes through the jets in the carb and if these jets are clogged the engine will die.
Jun 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
136 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
