The first neoprene (plastic) gear wheel that makes contact with motor shaft axel (Metal) is damaged. The metal shaft that has the teeth that match the neoprene (Plastic) has stripped the plastic teeth off, thus not allowing the gear to move. Where can I get a new Plastic gear for model OM 96578?
  • 86 Answers
What brand is it ? Shredder tech ( colorado) write back.
Posted on May 06, 2010
Pool pump clock
T104M used WG1573 clock motor:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The timer mechanism has metal gears, while the clock motor has plastic gears. If the metal gears get dirty and bind, it will strip the plastic gears.
Turn off power, pull timer out of box, Clean out timer with compressed air, and spray WD40, add a bit of white grease to lever where trippers make contact, then replace clock motor ... and buy another set of trippers to have on-hand since they are designed to wear down so timer will last longer.
If timer body is broken so dial does not rotate, then buy new T104 and snap new mechanism into old box. Buying whole T104 with enclosure is cheaper than buying T104M mechanism only.
May 15, 2013 | Pool & Spa
Wall-e u comand robot, will not move forward he just turns, can i fix the right wheel?
On the in side of the body (cube) is a white gear the size of a 50cent coin. It is pressed on a drive shaft. The inter ring is cracked and slipping. It makes Wall E turn around and around. I'm looking for a replacement or some one with a makerbot to reproduce it. If any one finds one let me know at. stevepiper@usa.com
Apr 19, 2012 | Disney Wall-E U-Command Remote Control...
I have a tp104 p3 intermatic timer and the clock is not working it looks like the motor for the gears are working but the clock will not turn
Motor has plastic gears.
Timer wheel has metal gears.
If metal gears are not turning, and clock is turning, plastic gears are probably stripped.
And metal gears might be dirty and rusted.
Look close where plastic and metal gears meet.
2 solutions:
1) clean metal gears and replace clock motor
T-104 takes T-100 series 208-277V clock motor
Add a bit of white grease where trippers meet metal lever
Grainger sells parts.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
2) buy new T-104 and swap out insides without changing box
Nov 12, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
When i turn the key forward the engine wants to start but doesnt just makes the roaring noise and doesnt start
It could be the starter, is it high pitch screeching, metal against metal, sound? Or more of whine? If it's metal against metal, the teeth on the flywheel ring gear might be damaged. If it's a high whine you are probably hearing the electric motor part of the stater and the "starter drive" is bad. The stater drive is part of the starter, it's the gear that engages with the flywheel gear. It is a one way clutch, it is supposed to hold when the starter is turning the engine. But, freewheel when the engine starts so it doesn't over rev the starter motor. When the drive goes bad it freewheels both ways. If you think the flywheel teeth are damaged you could try turning the engine by hand a little, WITH THE KEY OFF! Sometimes you can put a wrench on the alternator pulley nut and turn the engine a little. This will move the damaged teeth away from the starter and it might work now. Good luck.
Mar 12, 2010 | 1991 Chevrolet S-10 Blazer
Rear wiper quit on 2003 S-10 blazer. checked wires and they look ok. fuses are also good.
Good chances are that the motor has gone bad and will need to be replaced. It's a common thing for the rear wipers to stop working,
You can try this first if you got time:
Take the rear hatch apart (screws, spring clips, inner panel screws (12), etc) to get to the wiper motor. Close investigation, the gear box attached to the motor can be opened up. The motor obviously works since it chatters so something else is not working, makes sense. Opened up the gear box, the motor shaft drives a worm drive gear (plastic) that meshes with a gear wheel (plastic) that has an eccentric cam (metal) on the gear wheel that attaches to a metal arm that meshes with another metal gear arm that is attached to a long shaft that passes through the hatch door and terminates with the finely spline end of the shaft (where the wiper attaches to). As the eccentric cam turns around the gear wheel, the metal arm moves back and forth thus creating the wiper effect. Lot of action in a small space,(pretty cool actually). My basic philosophy is that if something can be assembled, it should be able to be DIS-ASSEMBLED (in theory anyway). So fiddling with the thing eventually led me to the conclusion that if you put the wiper nut on the end of the wiper shaft and gently tapped the nut, you could drive the wiper shaft (and its metal gears and arms back out through the metal housing (Oh, forgot to say that the wiper shaft was "rusted" in its sleeve and would not oscillate back and forth). At the end of the shaft (on the outside of the vehicle) there is a metal "washer" that was an incredibly tight fit (this washer holds the shaft from falling into the gear box) so you have to keep tapping on the end of the shaft to eventually drive the shaft past this holding washer. Once you get past the washer the shaft would not pass through its guide sleeve in the metal housing (remember, "rusted" in place, seized). So tapped it out with a Phillips screwdriver acting as a long punch. You can then cleaned the interior sleeve by reaming it with a long circular steel brush (3/8" diameter brush that is designed to clean out push rod holes) and polished the wiper shaft with fine sandpaper, then lubed and reassembled the whole smash making sure the wiper shaft now moves freely in its sleeve. Put it all back together in the vehicle and we'll see if it works. Fingers crossed. This may save you some money if it works.
Mar 05, 2010 | Chevrolet S 10 Cars & Trucks
Replace rear Axel !999 Ford F150 2 Wheel Drive
Fairly simple job...Unbolt everything connected to it, take it out, put new one in and replace everything you unbolted. Support the frame, so you can get the unit out and nothing but the diff comes down after all hardware is out. Most bolts are really tight and rusted , so be prepared to have them fight you and when getting one from junkyard, ask if you can have the hardware with the unit so you have spares on hand.
When buying the replacement, make sure it has the correct size driveshaft yoke on it.
This is a good opportunity to custom tailor the diff to your needs...count the ring gear teeth on yours and then divide by the number of teeth on the pinion this gives you the ratio. If you do a lot of low speed driving and pulling loads, you may want to change to a 3.90 ratio or even a 4.11. If you do a lot of long high speed driving, go to a 2 series rear ratio. If you are happy with what you had, match that. (changes require speedometer gear change or it will be a bit off)
Always change the diff lube when you change a diff. Never buy one without removing the cover and looking at gears and checking for fine metal in the lube.
Sep 17, 2009 | 1999 Ford F150 Regular Cab
The left side will not ingauge the right side works properly. I have taken it apart and checked and can't find the reason please advise.
I have a Craftsman self-propelled lawn mover on which the right-side front wheel will not turn when the belt is engaged. I removed the wheel and found that the plastic gear teeth on the inside diameter of the wheel were worn down. The metal gear on the shaft is still in good shape. This has happened before, and the fix was to replace the wheel.
Jun 12, 2009 | Craftsman Garden
Large Metal Gear Wanted
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Sep 14, 2008 | Cross Infoguard Shredder SX102M
Hello, I have a GBC Shredmaster 6120S
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc board has gone bad and you will have to contact your manufacturer for further parts availability.
Oct 02, 2007 | Office Equipment & Supplies
Grinding Sound
Only solution - Don't buy a FELLOWES shredder.
It is ludicrous that they cannot (will not) supply a spare gear wheel when there are thousands of instances of them failing. Or even think outside the box - fit metal ones?
Jul 07, 2006 | Fellowes PS80C-2 Shredder
473 people viewed this question
k24674
