Question about Garden
Have a 20 hp/50in cut statesman circa 2000, today without warning, the clutch/brake decided to disengage, thereby not allowing mower to move unless i put my foot under the clutch and pulled up so it would release the brake and engage the clutch. i am sure it is just\ an adjustment but i just acquired this mower a month ago and this occurred during the third cut...i can get it to work but not comfortable holding brake up with foot..sort of dangerous but i got the yard done...any ideas on this
  • 713 Answers
Hi,this solution will help you with the desired adjustment you need on your riding mower;
STEP 1 Put on gloves and eye protection, park mower on flat, solid surface, engage the emergency brake and remove the mower key. Then disconnect the spark plug wires to ensure the safety of the maintainer.
STEP 2 Locate the power takeoff (PTO) clutch on the mower. It is a small bell housing that should be attached to the underside of the engine, where it can provide power to the mower blades. The mower belt will be routed around the PTO---follow the belt and the PTO's location should become immediately apparent.
STEP 3 Locate the PTO adjustment slots. The adjustment slots are long, thin, rectangular openings in the brake plate that allow the maintainer to measure the gap between the rotor (the part that spins) and the armature (the part bolted to the engine).
STEP 4 Insert the feeler gauge into each of the PTO adjustment slots to check the distance between the rotor and armature faces. This will allow the maintainer to get an idea of the adjustment needed for the PTO.
STEP 5 Hold the feeler gauge in the first slot and tighten the adjustment nut until there is no gap left between the rotor and armature faces. Do not tighten the adjustment nut too far---the faces should just touch the feeler gauge.
STEP 6 Repeat the adjustment on the other two slots to ensure an equal adjustment at each of the adjustment nuts. It should be noted that even once the proper adjustment has taken place, the gap may vary slightly in each window. According to the Snapper operator's manual, "This is due to dimensional variations on component parts, and is an acceptable condition."
STEP 7 Reconnect the spark plug wires and start the mower. Engage the PTO switch so that the mower blades begin turning at full speed, and then disengage the PTO switch. If the mower blades and belt do not completely stop turning within five seconds of disengaging the switch, replace the PTO clutch assembly.
Thanks and take care
Posted on May 05, 2010
Gravely zt 48hd starts, blades engage and start, but mower will not move forward or reverse after lowering brake. suggestions?
There should be a lever/engagement clutch on the back of the mower. It is disengaged when you manually push it. It will have to be engaged again to allow it to move.
Jun 24, 2016 | Garden
My 2000 jd sabre lawn tractor, when you moving an push on brake clutch it will not stop.thanks
You probably have a broken linkage that is not allowing it to disengage look around on your full lace on your mower deck you may be able to drop the deck by removing some other clips and pins Jack the front of the tractor up in the air or suspended it from wench
Aug 07, 2014 | Garden
Clutch does not disengage gears
You either have a hydraulic clutch system or cable. What probably happened is your hydraulic system failed. You either have a separate reservoir for the clutch master cylinder or it shares the brake reservoir. Check under the hood next to you brake master, Too difficult to answer without more info on year, make and model.
Dec 15, 2013 | Garden
Sears riding mower will not start after it killed.
first thing you need to do is check and make sure the blades are disengaged set the park brake and try to start it again all newer mowers will not start without parking brake set or depressed and blades or pto in the off position good luck
Oct 07, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When i turn the key on the mower the engine turns but does not want to start
if theres a safety mech's on them make sure blades and pto are disengaged, also sometimes you have to depress clutch or have the parking brake set, just like if you are mowing and decide to stop and put it in nuetral if the blades are lowered and pto engaged when you leave the seat the motor will cut off. if that isn't it make sure your spark plug is pushed all the way on.
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Put on a new clutch safety switch today, same problem, mower starts fine then when I dis-engage clutch it stops running, runs fine as long as I hold the clutch/brake down! any suggestions
check the seat saftey sensor,,,sounds like its running because it thinks its brake is set.if your out of the seat it quits unless the brake is set.it will be under the seat.let us know either way we can figure it out..
Apr 14, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I would check to make sure you have the correct belt first.There is usually a belt dioagram in the manual and on a sticker on the mower.Then check the idler pivot bracket to make sure it is moving freely to allow the belt to loosen also there is a small spring p/n 169022 that pulls the idler pulley back to disengage the belt when you release the engage lever its is about 1/2 inch by 3 inches long on the center of the deck.Also there are 2 brake cams that lift the brakes off the pulleys make sure they are lubed with wd-40 where the roll across the idle plate,and make sure the idler plat does nat have a worn spot on it where the cam roller rides on it.
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
