Question about Cell Phones
Motorola V3 battery problems
Have a uk motorola V3 that hs developed the fault of draining the battery of power even when switched off. Sounds like some basic short circuit, but where?
The V3 is still on when turned off, With the phone off the alarm will still work, The only way to really turn it off is to pull the battery out.
Posted on Jan 30, 2009
SOURCE:
CTM HS-580 will not go, batteries are fully charged and no fault lights showing
H i, is there a click from the rear of the scooter when you push the lever to go forward or backwards ??
first of all disconnect one battery, now located the controller and follow the leads to the motor and brake , disconnect look at the connectors and refit , using contact cleaner if possible, making sure they are a good fit,,,
couple of points,,
The wiring from the throttle lever to the controller may be damaged so the controller never see's the pot move (resistance change) as it were..
At worse the controller may have failed, i offer a free testing service,, you only pay the return postage..
Regards
Rob
www.gewizrepairs.co.uk
Mar 30, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
Battery drains power even when car is off, bought
Someone will need to check all of the circuits to find the power drain.
Could be a stuck relay, short to ground, or faulty switch among other things.
Aug 10, 2013 | 1991 Toyota Tercel
My 91 firebird battery keep draining put new alt on test fine new battery fine drove it for a half hour and it died again whats wrong
You have a power drain ...and it sounds like a big one. Basically there will be a short somewhere in your cars wiring causing the power to drain from your battery, I would also check your car stereo wiring as sometimes they are the fault
Mar 01, 2011 | 1989 Pontiac Firebird
My daughters 2003 Toyota Echo is eating batteries. I bought a new battery from AutoZone about a week ago and it is already dead. The altenator was checked and checked good. She told me the car is also...
You may have a "parasitic battery drain". (Hint: google "finding parasitic battery drains") Basically, there is something "on" that is draining the life of the battery even while the key is off. Common sources are courtesy lights under the hood and in the trunk; even in the sun visors. Also, anything that is hooked into the cigaretter lighter (or "power port") circuit. These items could be aftermarket car alarms, inverters for operating portable electronics, phone chargers etc. If you eliminate all these and still have the battery draining down, you may have a low amperage short somewhere. To find the circuit responsible, you will have to connect an ammeter in series with the battery negative cable. Say for example that it still shows a .1 amp drain--even with everything turned off. Start pulling fuses one at a time until the amp drain reads zero. The problem will be on the circuit of the last fuse you pulled. From there, you'll have to try and disconnect each item on that circuit until you find the culprit. It sounds tedious and it is.
Jan 26, 2011 | 2003 Toyota ECHO
Battery in Motorola RAZR V3
I couldnt find anything that says that exactly but if it keeps happneing then most likely that is the case. There are no active recalls for that battery from motorola so most likely there is something on the phone a short or something that could cause it to overheat or overcharge thereby hastening the wear and tear on the battery
Aug 22, 2008 | Motorola Mobility RAZR V3
Battery
well...sir they do die quickly no matter the age of the battery......but you should buy a new one
Jan 26, 2008 | Motorola Mobility RAZR V3
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Motorola v3 short Circuit. Pl help
if it has short-circuited it is best to have a professional mobile tech or service center repair your phone.
Nov 10, 2007 | Motorola Mobility RAZR V3
Battery
Turn on the battery save feature and select a slow search frequency.
Nov 09, 2007 | Motorola Mobility RAZR V3
Turns off all by itself
Sounds like you have a bad connection to your battery. Check the battery or the connections for debris or corrosion. Clean it if there is. If they are clear it could be the connection inside the phone on the circuit board or a short.
Jun 05, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
82 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
