Question about GE Spacemaker JVM1640SJ Microwave Oven
The vent fan and light do not work. - GE Spacemaker JVM1640SJ Microwave Oven
  • GE Master
  • 9,085 Answers
Have the cooktop lights failed recently?
If so, then the circuit board may have been damaged. We repair those.
Or does it just fail to fully "come on" when you press Start?
That may just be a bad door switch.
But to know for sure, we'd need your brand and model number and more specific details on how it's failing.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 06, 2010
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
Vent fan has stopped working. the keypad says vent fan off. when pressing help, it says press this pad. nothing happens.
A low tech solution worked for me.
I too was getting the "Vent Fan Off" message, and despite the fact that everything else worked fine with the microwave, I turned the breaker off and back on from my electrical panel. The fan works fine now.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The second under cabinet light went out with a pop, and the vent fan went out with it. Is there a fuse for both somewhere? The turntable motor and light and fan still work. Will th vent fan come back on if...
There is a varistor or thermostat switch mounted on the wall behind the control panel. I unpluged the leads and shorted them together. the fan and lights started working again. I got another microwave off freecycle.org for parts. I noticed a lot of sites tend to point to the control panel for a $36 to $100 board repair. Don't fall for it. H.G.
Jan 03, 2010 | GE JVM1660 Microwave Oven
GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Sep 11, 2009 | GE JVM1750SMSS Microwave Oven
Samsung SMH7178STD microwave fan stopped working
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
Dec 03, 2008 | Samsung SMH7178STD Microwave Oven
GE Microwave oven
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 17, 2008 | Microwave Ovens
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Lights and Fan not working
Are you talking about the light and fan inside the microwave or the vent fan (in the grille) and the cooktop / stove top lights? Either can be economically repaired. Please clarify and I will give you more detailed information.
Jun 24, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
83 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
