Ive got a Vulcan Gas dusted Heating system -
Ive got a Vulcan Gas ducted Heating system - product # 5310052 ...wouldn't start from yesterdat...ive gon onto the roof and noticed once the dial is turned on it starts for 10 seconds and stops..do you whas wrong
  • Anonymous Mar 18, 2014
    I have external Vulcan gas furnace model 902 for ducted heating. Recently RACV home assist checked it and advised heart exchanger is cracked and needs to be replaced. Where can I get it?
  • 674 Answers
Possibly a bad thermocouple or whatever is sensing the flame. If its a flame rod you can clean it with steel wool. Let me know what you find.
Posted on May 06, 2010
We have vulcan ducted heating. not much air comning from vents. what could be the problem
Could be simple as collapsed ducting, blocked return air filters, broken ducts, loose fan belt ( if belt driven unit)
Jun 06, 2017 | Vulcan Heating & Cooling
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Im about to buy a 2009 kaw vulcan 500 and #1it needs a battery and #2 Ive forgotton how to ride (shift gears) and #3 im not sure what model it is
Batteries are easy and cheap to come by. 40-60$.
Shifting:
Starting from bottom to top shifting goes as follows: 1-N-2-3-4-5-6. Just pull in the clutch before you shift and release afterwards. Remember to release slowly when you are first accelrating from a stop.
Vulcans are great beginners bikes. 500cc is perfect to learn on and the Vulcan is very user friendly. Easy to start up and get going even when its cold, comfortable riding position, and strong enough to make freeway riding enjoyable. For a used 2009 i wouldn'tpay more than $3500 in good condition
Jul 28, 2011 | kawasaki Vulcan 500 Ltd EN 500 C...
Bonaire Vulcan ducted heating system flashes F08 and HC 01. What do I do?
I was able to fix my Pyrox ducted gas heater (flashing between HC01 and F08 by pressing the reset button on the main PCB located in the main heating unit.
The reset button is located next to a set of indicator led's. It's easy to get to by just removing the covering shroud.
May 02, 2011 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Thermostat wont work
Go down to your heater and find the thermostat wires. there should only be 2 wires connected, One will be connected to R and the other to W match them to RH and W on the thermostat. The jumper will not matter.
Aug 13, 2009 | Heating & Cooling
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
Heating & Cooling Logo
1,063 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
