Question about Sony PlayStation 2 Slimline Console
Please someone help me! I have a slim 90001 series ps2 that is not working. I've replaced the Motor/laser, power button and all ribbons and white cables and it STILL will not play any dvd, cd, PS1 or PS2 game. PLEASE help me, I'm running outta ideas and money!
  • hellkitten66 May 05, 2010
    Yes the solder has been removed. The laser works in a different ps2 that I have, but not the broken one.
    Sergeant:
  • 166 Answers
When you received the laser (optical pickup) did you unsolder the static point on the laser board before installing the laser or check to see if there was one?
If there was one and you did not unsolder it will not allow the laser to work. They are usually near the back and are a drop of solder and when unsoldered they tent to look ( | ) like separate pads.
Posted on May 05, 2010
Testimonial: "This was excellent advice, but unfortunately not the solution. Soldering has already been removed."
  • Scott Fuller
    Scott Fuller May 06, 2010
    My next suggestions:
    Can you verify that the TRV base (the spinner) is moving and is the laser worm drive motor working? If they are, the next thing I would suspect is the board that controls the function of the drive (the controller chip) or board itself.
Ps2 slim 90001 no power
maybe u play it to much or some thing is wrong with the plug or u can open the ps2 check wear the plug goes in
Jul 23, 2009 | Sony PlayStation 2 (PS2) Console
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
My Ps2 light turns green then turns red
check to make sure your power cable is securely in, and check for any damage in the cable
Jan 30, 2008 | Sony PlayStation 2 (PS2) Console
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Playstatiion 2 repair
Hi Jaybs,
The disc will not spin if the laser canot read the disc. you may have a dead laser or bad ribbon cable that runs from the Laser to the motherboard. I am posting a procedure to clean the lasers lens. I hope you do not have the Slim model, as this procedure is for the older Big size PS2. You do not use Alcohol on the lens of a Slim PS2 ,it tends to haze over the lens.
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 07, 2007 | Sony PlayStation 2 (PS2) Console
My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
  4. REmove the Warranty sticker to the right edge of the power socket.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  10. REmove the little white disc from the Cd tray lid.
  13. Put it back together, and your in business.
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Read Error
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
About my ps2.
Hi Jzone,
Oct 22, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
218 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
