Question about Hawking HWREG1 Repeater
Just pluged in my HW2r1 repeater. The light on
Just pluged in my HW2r1 repeater. The light on the repeater is flashing quickly to show I have a wireless signal. When I turn on my laptop to find the signal from the repeater it is not listed? What am I doing wrong? I tried to find the signal on two different laptops.
3 Suggested Answers
  • 6 Answers
SOURCE: HW2R1 repeater is providing an
Is it the repeater or the modem or router.
If you bypass the repeater does it still do it? If not then you might have to "Hard" re-set it. Check your manual on how to do it. It usually involves putting in a paper clip and/or pressing a button but each one is different. You WILL have to re-enter everything again but it's set back to the Default configuration.
If you bypass the repeater and it still happens then it's either the DSL/Cable modem or the Router. Just turn them off or unplug them for 30 seconds or so and then plug the modem in first wait until it's done then the router. Unplugging them or turning them off is considered a "Soft" re-set and just clears the temporary memory and doesn't erase anything else so no reconfiguring.
If after all that maybe it's going bad? Contact the Manufacturer and ask for more answers? They will probably ask for the Version and firmware number to know which exact model you are talking about.
Posted on Jan 08, 2011
SOURCE: My HW2R1 router keeps disconnecting
You need to reset router to defaults. Also change wireless channel type to 3 or 6 or 11 then check.You can configure channel type with below method .
Press RESET button for 10 seconds it is in the back side of router then all settings defaults. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on May 15, 2011
Sharp LC-46D77X TV won't turn on. Showing two short red flashes.
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 16, 2015 | Sharp Televison & Video
Error Code? 2011 Mazda 3 Sport Airbag Light Flashing.
suggest you get it to Mazda to have problem diagnosed - your safety system could be compromised
Dec 17, 2014 | 2011 Mazda 3 Sport
Where is ghe router 8 digit pin number for the hw2r1
Ping numbers (Or WPS numbers) are usually on a sticker on the bottom of most wifi / wireless devices. This is ONLY if they support WPS.
If you are sure the device supports WPS and a sticker is not on the bottom you may have to log into the device using a computer that is hard wired (Ethernet cable) to the device.
If you have lost the manual you can download a new one from here
http://hawkingtech.com/products/downloadfile/107.html
Note this link is for the manual to a Hawking HW2R1 ONLY.
Aug 07, 2014 | Hawking HW2R1 Dual Radio Smart Repeater
Hawking HW2R1 repeater doesn't get internet
first of all bring the repeater closer to your router (after upgrade you can return it to its original location)
Mar 25, 2017 | Hawking HW2R1 Dual Radio Smart Repeater
I have a 1965 suzuki k15. i lost the keys and need a wiring diagram so that i can bypass the ignition, but still make everything on the bike work. Any help would be greatly appriciated.
all the key does is add an extra path to ground for ignition and charging the coil as 3 black wires take plug out leave pluged in kick over pluging and un pluging one wire out of the connector till you see spark then simply repeat for lights look for lamp to come on while running when unpluging a wire if not it unplug try another theres very few wires should be a quick process
Mar 31, 2011 | Suzuki ST 250 Motorcycles
HW2R1 repeater is providing an intermittant signal and shows no sign of connectivity. We have turned it off and on again but no result. Suggestions?
Jan 05, 2011 | Hawking HW2R1 Dual Radio Smart Repeater
Hawking HWREG1 Repeater Logo
121 people viewed this question
Top Hawking Computers & Internet Experts
WTF Chuck.....
WTF Chuck.....
Steve
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
