Question about Grinders
I have a Craftsman Commercial 1/2 HP Bench grinder. When I turn it on It just hums. It doesn't turn. Can you tell me what is wrong and which part I need to change? Thank you, Marlan PS: I have misplaced the manual.
  • 10,319 Answers
The motor has a high spot on the armature causing the motor to stop rotating. The humming noise is the fields full of current which is making the armature to react to make this noise. For the money purchase a new bench grinder which is an easier fix than dumping money into your old one here
Posted on May 05, 2010
Looking to replace obsolete switch on Craftsman 1/2 hp bench grinder. Sears lists part as 4984992
This switch is a very close fit, and it is rated for 20A 120VAC.
2LNA7 $11.09 / each
Grainger
I've used it on that vintage Craftsman bench grinder.
http://www.grainger.com/
Dec 12, 2015 | Craftsman Grinders
Is the 4A912B Dayton 10" 1 HP bench grinder 3 phase or 1 phase?
If the plug on the cord has 2 flat prongs and one round one then its 110 VAC single phase. If the motor has 4 wires then I'd suspect 3 phase. The data plate on the motor will tell you for sure.
Nov 19, 2014 | Bench Grinders
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
Apr 24, 2011 | Baldor 8" 1 Hp Electric Bench Grinder
I have a 1/3 hp motor with a capacitor. There are four motor leads coming out of motor, the capacitor is mounted in the wiring box. This motor does not have a centrifugal switch, to isolate the capacitor...
I am in the process of replacing a capacitor on a Craftsman 6 in 1/3 grinder, 2.8 amp, single phase, 110v. Not sure on the centrifugal switch. model 319.190621, ser B9530. When I took the old one out the black wire from the capacitor went to the cluster of back wires (in my case 3) in the wire nut. The blue wire from the grinder went to red wire from the capacitor in a wire nut. Hope that helps you....
Maybe you can help me... the specs on the capacitor burned off when it failed. Can you tell me what the capacitor specs are on yours?
Nov 16, 2010 | Craftsman 6" Bench Grinder with Lamp
I have a Taiwan made 1/2 hp bench grinder that wont run only hums and now it wont even run if I spin it by hand and no capacitor. Is it junk now.
Hi there, with out seeing it I`d say your brushes are gone and ceasing. I hope this solves your problem.
May 18, 2010 | Grinders
I need a replacement switch for a craftsman 1/2 HP bench grinder model#397.19441. I have no owners manual or parts list. This grinder is several years old.
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Dec 28, 2009 | Craftsman Grinders
Older sears bench grinder wont run 1/3 hp model 397 19581
I know this is an old post, but maybe it will help others looking for information.
I have the Craftsman 1/3-HP grinder models: 397.19580 & 397.19581.
They are Split-Phase single voltage (115 V), and use a Klixon start-up current style relay - 2CR14-224.
The relay is normally open. When the large starting current in the main/run winding circuit is sensed by the the relay coil (term 3 & 4) which is in series with the main winding, the relay contacts close (term 2 & 4).
The one end of the start-up winding is connected to the main coil's BLK wire in the coil pack.
When the relay contacts close the start-up winding is energized. The start-up coil is used to provide a boost to over-come the resting inertia of the rotor.
Once the rotor reaches between 65% - 75% of operating speed, the current through the main winding circuit is reduced to the point that the relay coil cannot over come the return-springs force, acting on the relay contact arm. With the contacts open, the start-up winding is no longer energized.
This should take about 2-3 seconds, if the relay malfunctions, the high current through the start-up windings (thin wires) may be damaged.
Here is a diagram I have made.
Klixon 2CR relays are no longer available.
You may find a suitable replacement here:
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_
May 31, 2009 | Craftsman 6" Bench Grinder with Lamp
Grinders Logo
354 people viewed this question
Top Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
