Question about GE 1106P DVD Player
Hooking up to the television s-cable and two audio jacks. I have a picture of the dvd but the sound comes from the television program in the background
  • 736 Answers
The S Video cable and the two audio cables should be plugged into the same av input on your television. It sounds like the sound cables for your cable box or satellite tv box are plugged into the television where the two audio cables for the DVD player should be.
Posted on May 06, 2010
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Trying to hook up my dvd player,picture comes in black & white and no sound
Hi,here is my simple solution...
to listen your DVD on TV
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your DVD ,
** to both "AUDIO input " and VIDEO input" of your TV or "Optic Cable input"
** than just switch to respective mode on TV as A/V selection
of your RCA or Optic connection..
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
There you go..Both DVD sound and Video are on the TV .By this means whatever you watch on the DVD will come thru your TV.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jun 29, 2011 | Televison & Video
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
We just bought a new 32" panasonic led tv. Hooked everything up and works fine with normal television broadcast. However, we have a Sony DVD/VHS combo hooked up that doesn't perform well. When we play...
If you are using the composite cables (RWY) make sure the red and white are plugged into the audio jacks and NOT the component cable plugs (RGB.) If you have the red audio cable plugged into the red component plug this will cause issues, especially with the sound.
Aug 10, 2010 | Panasonic Televison & Video
Need to find out if older model phillips tv is dvd compatilbe?
If you dont have rca jacks on tv then you will need to get a converter bob with rca jacks in and anti out to tv or youcould try using your vcr with the rca jacks on it and put rca cable from dvd out to rca vido in and audio in then hook up your anti cable out to anti in on tv.should work cam corders do.
Mar 05, 2009 | Philips Televison & Video
I wanna hook my laptop to my tv. used a vga cable and get picture but no sound
You also need an audio cable to go along with the VGA cable. You will need a 3.5mm audio jack cable. Plug one side into the headphone jack of your laptop, the other side into the 3.5mm audio jack that is right beside the VGA connector.
Jan 29, 2009 | Televison & Video
DVD Player not working
Go to menu. Select inputs. Assign input 1(or whatever input you connectedthe dvd to) as DVD. Then exit menu. Press the input key, scroll over to DVD. I reccomend using a component cable with a digital audio cable, if you do not have a DVD player that has an HDMI connection. You will find that a blu-ray player will be much more satisfying for the television you have. Basically by hooking up that old dvd player to that tv, is the same as hooking an 8-track to a $2,000.00 stereo. It will work, but the quality is going to suffer! Good luck, and believe me. It is worth the extra money to get a blu-ray player. It will play all your old dvd's and blu-rays. That way you are getting the full potential of your set.
Dec 22, 2008 | Mitsubishi WD-60735 Projection Television
Hooked up dvd and vhs player good picture no sound please help
look carefully whether you jacked the audio out from DVD and audio in into the TV
> the TV is having a Audio out and in jacks
>if you jack a the audio out from DVD into Audio Out in TV you wont have audio
May 08, 2008 | NEC MultiSync LCD4010 40 in. Television
DVD Connection and Surroundsound 7.1 Onkyo
gotta use rca audio cables in addition to the hdmi on this tv
Feb 09, 2008 | Philips 51PW9303 51" Rear Projection...
GE 1106P DVD Player Logo
75 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
