Question about Refrigerators
Our 3 year old frigidare does not get cold any more. the compressor is hot and the fan is continually running. The ice maker stoped making ice. the freezer temp is over 40 degrees. I was told it could be the defroster timer stuck. I was told I could turn the timer and kick the unit out of a defrost mode. WHere would I find the defrost timer and does the frigidare units 3 years old +/- have the timer switch that can be twicked? What other things can I do to troubleshoot?
  • solarch May 06, 2010
    The frig is a frigidare 18 CU' basic from Home Depot. I went to other stores and it looks like the same frig they had 3 years ago. I'm not sure of model # it is 80 miles away in a mt. cabin. No repair person would go for less then the cost of the frig.. THe Timer should be some where in the freezer, behind the panel or down under somewhere.. Is there a place to get diagrams of the frig to show us?
    THanks.. THe fan does run but the big black thingy is hot. the coils are clean.. Should I replace a starter device ands where is it?... Mark
    Master:
  • 497 Answers
PLEASE TELL ME THE EXACT MODEL OF YOUR FRIGIDARE, OK?
Posted on May 06, 2010
  • 17,970 Answers
PLS, tell us the make, model and serie about your frigidaire for send specifici details.
Posted on May 05, 2010
  • ZJ Limited
    ZJ Limited May 06, 2010
    Many times the refrigerator is turned of with the freezer door shut.
    This causes the fan motor to rust on the ensd of shaft. Remove back
    panel of freezer (unplug first) put a little 3n1 oil on the fan shaft
    give a spin then plug in and make sure the fan continue to run.
    The start device on the back of the refrigerator compressor may have failed. Specialy if the big round black thing is hot.
    Hope help.
  • ZJ Limited
    Try to check this article: repair-help
My 26lb silver portable ice maker wont make ice?? Any suggestions???
does it run? does the compressor run, does the fan run, is the air flowing across the outside radiator, is the air comiing out warm? is there a waterpump and does it run? Does anything get cold and does anything get hot?, it should be. These are my suggestions to look for in your unit
Dec 31, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Jenn-Air JCD2389GES problems
The condensor fan cools the condensor coils. If it is running this will cause a no cool situation. Also, if the condensor coils are plugged with dirt that insulates the coils and causes a no cool situation. These things will make it so the freezer isn't cold enough to freeze water so the icemaker will not produce ice. As far as the door edges getting hot. A condensor line runs thru the cabinet between the doors and this is called the mullion. If it is too hot this is a good indication of a bad condensor motor or dirty coils. Clean the coils and check the status of the fan motor and let me know what you find and we will see if we need to go further.
Nov 11, 2007 | Jenn-Air JCD2389G Side by Side...
Zdis15
check hot gas valve to make sure it is not bypassing when in freeze mode this will not let the evaporator plate get cold enough. need to check refrigerant pressers.
Jun 07, 2013 | Kitchen Appliances - Others
Unit is about 10 years old, bought new from Lowes. When I open the doors the bar or middle frame is warm to hot. Now the freezer and refrigerator is not cold. Ice started to melt down so I removed the ice...
I suspect the warm to hot is from a heater that keeps moisture from from condensing on that bar. you don't notice it when the unit is working properly. Make sure your condenser fan is running and that condenser is clean. You may have a compressor that is failing
Jun 23, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
NOT GETTING COLD
the first thing to check is the thermostat if its stoped working them it wont be telling the compressor to start up and the unit wont get cold,,
have this looked at first as its the cheapest part to renew
May 22, 2010 | GE Profile Arctica 25.4 Cubic Feet...
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
I have a u-line bi-95 ice maker.the machine will only drop ice once after it is turned on. i also notice it gets very hot near the vent.the machine does get cold enough inside to keep the ice.what should i...
Your unit will only harvest when your thermostat is satisfied. If you have heavy frost you need to defrost the unit. If no frost then make sure the fan is running by the compressor. If the fan isnt running then the compressor is going off on overload. Or it could be the fan running but the compressor is not. If thats the case you will need a service tech.
Aug 03, 2009 | U-Line Icemaker
COMPRESSOR RUNS, AND IS HOT TO TOUCH, FREEZER WONT STAY COLD IF O
either your evaporator and condenser coils are very dirty or your low on r22 freon
Jul 31, 2009 | Freezers
Fridgidare/Electrolux top freezer not freezing fan stays on.
Look for ice buildup on the back wall of the freezer.
If ice is there you have a defrost parts issue.
If not, check the compressor to make sure it is running.
Mar 04, 2009 | Electrolux Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
