Question about Goldstar R6004 Air Conditioner
Wont shut off
Where do i get a thermostat for this unit and also a r5207 unit
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Greer appliance parts, tulsa ok 9185873346
Posted on May 08, 2010
My 18,000 BTU LG window AC: The compressor wont shut off.
replace the thermostat
of course it will not stop if the air in the room is not controlled ( doors open , window open, room to big fore the ac unit or if the temp control is set too low ( 25 c is optimum setting)
Aug 10, 2016 | LG Heating & Cooling
Central unit
Seems like defective wiring or thermostat. The thermostat wires needs be checked. Another thing if the ac unit has economizer feature.
With the thermostat removed, if possible wires still connected to thermostat base, jump R-G, indoor fan should turn on: jump R-Y, compressor and outdoor fan should start (may feature a few minutes time delay): jump R-W, heater should start and indoor fan after a time delay.
What you want to see is R-G and R-Y working and if this is no problem, the thermostat may be due for replacement
Jun 21, 2015 | Heating & Cooling
My dryers heater wont shut off so it gets real hot
The heat is not sensed out and so the control secctionis faulty .
It can be primarrily the thermostat or then the next opttion is the control timer unit.
Replace the unit if you are not able to see/test a defective component. Trigger test the thermostat on the control unit and if it works the therrmostat is faulty,
However if there is no reponse, then the control unit is faulty.
Aug 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Units heating elements wont shut off regardless of what mode is selected on goodman units thermostat model no. ar24-1
Hi, you will need to replace this thermostat as the circuitry is faulty and keeping the strips energized. The only way to check would be to pull cover from stat and expose stat wires. Power off first. Disconnect the 24 volt hot wire, red and they should shut right off. If so get a new stat. If you need further help, please contact me. Merry Christmas.
Shastalaker7
Dec 24, 2009 | Goodman CKL24AR24 Air Conditioner
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Carrier unit runs all the time, never shuts down and the fan in the house will not shut off ' the house isnt getting beloe 80 degrees inside, even though I have the thermostat set at 76, I turned the...
Ya need preventive maintenance preformed evaporator clean condenser cleaned and the blower wheel clean unit could be under charged have it tuned up and your electric bill wont surprise you leave it running like it is and you will have a very large bill
Jun 27, 2009 | Heating & Cooling
Thermostat wont shut off unit
These units are bad about that. you have to mount the cap sensor in the small tube that runs thourgh the evaporator for proper operation. laying on top of the coil does not let the thermostat sense properly.
Jan 02, 2009 | True 598-TSSU608ADA SandwichSalad Unit 155...
A/C Problems
SOUNDS LIKE THERMOSTAT IS NOT SET UP CORRECTLY THE HAVE TO BE PROGRAMED TO YOU UNIT
Aug 28, 2008 | Honeywell Electronic Programmable...
AC wont shut off
while unit is running tap control to see if it shuts off or turn therm. up to 80 if still runs replace control (warranty)
Dec 14, 2007 | Fedders AEQ07FBG Air Conditioner
Goldstar R6004 Air Conditioner Logo
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
