Question about Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range
Oven heats up then cuts out, no light etc then comes back tolife after 5/10 mins.
Saw you comment about the in line resistor, wondered oif you might know where I might get a new one and how do I fix it? Is it possible that the thermostat is faulty?
Thanks for your time
Peter
Check that the cooling fan is working by feeling for air flow between the front panel and the top of the oven door. If air flow not present suspect the cooling fan or the inline resistor (could be open circuit)
Posted on Sep 12, 2009
  • Geoff Mar 18, 2013
    I had this problem. If the cooling fan at the back top right is not running can hear/feel at fron as stated above. Then the top overheats and the overheat trips the shut the entire oven down - it will reset when cooled down - maybe an hour later - (remember to reset the clock ). The fan in may case was getting no power because the white ceramic in line resistor - rated 470ohm had burnt out internally. There is also a PCB board which controls the fan running which is mounted middle left at the back. The fan itself also could be faulty. Either way all easy fixes accessible by taking off back panel if you know your electical safety- No live working.
Sounds like it could be the thermal cut out switch - I am having a similar problem. The switch is about £10 delivered from the Stoves spares dept. I can't work out how to open the top to change the switch though! Have you managed to solve the problem and can you add anything re opening the top?!
Posted on Jul 04, 2008
    More likely a fan problem. Thermal switch is doing its job - operates after oven heats for about 20 mins because top has got too hot. See above
Oven baking element lower heat source doesn't heat
Check valve for power, if power is there than look for part elswhere as 166 is a lot. Mine was 40 but you do not state make or model
May 18, 2015 | Kitchen Ranges
Diplomat Gas Oven cuts off after few mins
The oven is probably overheating and shutting itself off to prevent damage/fire. If the cooling fan isn't running. Check/replace the thermostat that switches the cooling fan on.
Aug 02, 2014 | Hotpoint Diplomat Oven Grill Selector...
Tv works fine,cut it off and it will not come back on . Red light blinks 6 times, then repeats itself.
this is an indication of a overcurrent/ overvoltage error....meaning short in a voltage supply. I have seen this problem in the shop with this set. IN MY CASE it was shorted convergence chips. but it could also be any of the low voltage supplies 5,10 15,-15 lines
Oct 16, 2010 | Sony KP-53HS30 53" Rear Projection...
Thermostat keeps cutting power off to elba excellance oven
I have a similar problem with an Indesit oven. There are two thermostats one controlling the oven temperature which i think you have replaced and another over-temperature stat to prevent the oven getting to hot should the temp stat fail to control the temperature. The over- temperature stat could be operating to quickly and this cuts power to the the digital display, oven light, temp light and circulating fan. I am going to replace this over-temp stat
Jan 18, 2010 | Lux Elba OV 5085 LUX
Whirlpool oven door won't open after self cleaning.
I had the same problem. Hold down any button for 1 minute. That should reset the memory.
Mar 30, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven cuts out
Most of the time it is a temp sensor in the oven. We bought a service manual at houseneeds.com and fixed ours.
Nov 30, 2008 | Ovens
Fan assisted oven keeps going off ?
there is an overheat stat and this is cutting the oven off
things to check are.
is casing fan running ok? (this is the tangential fan inside the casing at the back and not the fan inside the fan oven)
this second fan is turned on by a fan stat. maybe this is faulty
is there plenty of ventilation?
is oven in fact overheating?
Oct 18, 2008 | Ovens
Smeg SUK91MFX5 oven wont heat
Reset the clock that will make the heating element work, if your clock has stopped displaying (common fault) set as per instructions but you wont be able to set at any acurate time.
Sep 16, 2008 | Smeg SUK61MFX Gas Kitchen Range
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
490 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
