Question about Sony Cyber-shot DSC-T100 Digital Camera
Sony Cyber-shot DSC-W90 con E:62:11
La cámara opera normalmente, toma las fotos y videos y puedo descargarlos, pero no sé que tan recomendable sea seguir usándola y además es molesto este mensaje contínuamente en el display.
Cómo corrijo esto?
Gracias por su ayuda
Juank
Colombia
5 Suggested Answers
  • 566 Answers
SOURCE: Cómo puedo que mi grabadora sony
Descarga esto software Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit Windows versiones no son por el suportadas.
Posted on Jul 28, 2009
  • 1382 Answers
SOURCE: I HAVE A SONY CYBER
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Thank you !!
Posted on Aug 18, 2010
  • 1566 Answers
SOURCE: DSC-N2 ho sempre scaricato le
Would it be possible if you can translate the information in English? Almost all of the experts here are fluent in English. We should be able to assist you faster if that is the case.
Posted on Sep 14, 2010
muntejaya
  • 10421 Answers
SOURCE: extravie el disco de instalacion
Kindly get it here : www.softwarepatch.com/utilities/sony-digital.html www.driverskit.com/freedownload/Camera/Sony/Digital_Camera.../18763.html www.sony.co.id/section/downloads
Jay
Posted on Feb 10, 2011
Hola, mi camara no dispara correctamente, al presionar el disparador se traba y aparece un rotulo en la pantalla que dice presione nuevamente y luego termina la foto, las fotos son de buena calidad... pero...
Cuando esto sucede en mi Nikon D-90, recibo un mensaje "ERR" en el panel de control. Nunca he conseguido un mensaje "vuelva a intentarlo". Sin embargo, suponiendo que esto es el mismo fallo, el manual del usuario dice que esto es un fallo de c?mara que puede ser aclarado por liberaci?n del obturador. En mi D-90 s?lo puedo hacerlo girando la c?mara y otra vez. A veces, tengo que quitar y volver a colocar la bater?a. El manual dice que si este problema persiste, debe enviarla a un centro de servicio autorizado de Nikon. Si lo que he sugerido que el problema no soluciona, sugiero que contactas Nikon support en www.Nikon.com para ver lo que proponen.
Dec 01, 2012 | Nikon D60 Digital Camera
Mi video camara es canon Dc210 DVDcamcoder no acepta los DVD que le pongo de ninguna que puedo hacer
El manual dice que algunos discos no vas a funcionar con la cámara, pero por supuesto no hay nada en el sitio de eso.
Yo sabía acerca de un problema similar, ya que estaba tratando con los discos DVD + RW. He encontrado algo la solución en la web de Canon: DVD-R/RW y DVD + R / RW son similares, pero en general los formatos no interchangable.
Las videocámaras Canon DVD sólo utilice discos DVD-R/RW. DVD-R/RW y DVD + R / RW son similares, pero en general, los formatos no interchangable. Las videocámaras Canon DVD sólo uso * DVD-R/RW o DVD-R DL (DC10, DC20, DC100, DC40 y no son compatibles con discos DVD-R DL). Si un disco DVD + R / RW se carga en una videocámara Canon DVD de la videocámara mostrará un mensaje "Error de Disco" después de que intenta leer el disco.
* Discos DVD-R de doble cara también se puede utilizar sin embargo, cada lado deberá ser inicializado antes de su uso.
Espero que esto le sea de ayuda; recuerde calificar esta repuesta. Suerte.
Sep 26, 2011 | Canon DC210 DVD Camcorder
Tengo una grabadora digital RR-US395 Voice Editing ver 1.0 pero el CD no me funciona con win 7. que puedo hacer
Hola que tal, desafortunadamente hasta donde yo sé Panasonic no ha actualizado Drivers para Windows 7 desafortunada mente así pasa a veces, en realidad té recomiendo que si vas a invertir en otro equipo consideres tus opciones ya que la verdad es mejor una grabadora de voz profesional y de una Marca líder en el ramo de las grabaciones como Olympus Philips o Dictaphone normalmente cada que sale un sistema operativo nuevo se actualizan muy pronto con el asunto de los drivers yo te recomiendo esta grabadora por su precio creo que vale la pena cada dólar http://www.tvps.com/Products/Philips-9380-Pocket-Memo-Digital-Recorder---New-LFH-9380__PH-LFH-9380.aspx
Apr 16, 2011 | Panasonic RR-US395 Digital Voice Recorder
Hola. el prblema que tenia al principio con este
CERTIFICADO DE EXPERTOS AQUI TV, siga esta información que he proporcionado tres soluciones de largo a este tema / s
Solución 1
Antes de empezar a desmontar cosas, le permite probar su simple rutina retire el enchufe de alimentación y sistema de poder una copia de seguridad. También, por favor, intente su unidad en una canales diferentes para ver si el problema persiste en cada canal. Su principal del Consejo, Power Board, T-Consejo Regulador se sospecha que los problemas en este momento. Pulse y mantenga pulsado el botón de encendido durante unos 15 segundos, la unidad debe apagar por sí mismo después de haberlo encendido. Si no es así, entonces no te preocupes. Quiero saber si el problema persiste. El primer enlace a continuación le llevará directamente a la guía de solución de problemas si tiene que seguir adelante con el mismo error.http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Información adicional No se pudo TV y Monitores: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plaguepartes: www.shopjimmy.com
Le permite centrarse en la parte externa de la primera serie de televisión (95 por ciento de todos los problemas de la televisión están relacionados con cosas externas a la propia televisión) Compruebe la conexión física de todos los cables mediante la eliminación de cada cable pelado o RCA y volver a instalarlo (Cada cable de potenciaasí), una vez que haya quitado un cable, compruebe que no se deshilache, y si ya está desnudo, de empalme de una conexión nueva y fresca para ello. 5. Asegúrese de que NO hay otras radios uneeded, el sistema de las cercanías.estos sistemas, cuando se enciende, hará que la interferencia electromagnética y evitar que más que grave la interferencia de televisión SURGE PROTECTOR protectores contra sobretensiones representan más del 75 por ciento de las fallas eléctricas a los equipos de estéreo. Vamos a empezar con su toma de CA de pared. Es norma en América que 220 voltios de fuera de estos puntos de venta. Esto implica que cada dispositivo va a utilizar 220 voltios (dentro de esa zona de la red). En todo caso incluye un reloj de alarma está conectado a cualquier enchufe de salida de CA en las proximidades del equipo estéreo / TV, causará interrupción eléctrica, electrónica e impedir incluso de encender! El televisor necesidades dedicada energía eléctrica.Si el televisor se encuentra en la sala a continuación, desconecte todo lo demás en la sala de estar. Permite conectar el televisor a una toma de Dedicado. Revise todos los interruptores de luz para asegurarse que el poder es para el que toma. Compruebe el cable de TV para Desfibracion tanto en el extremo de la pared de CA y donde se conecta a la televisión.Compruebe todos los puntos de GFCI para garantizar que todos los botones rojo de reposición se empujan, compruebe los interruptores automáticos para la conexión adecuada y que están encendidos. Ahora, vamos a tratar el televisor sin que relacionada con cualquier servicio de cable, vídeo, dvd, equipo de música, etc Por favor, responda si hemos encontrado una solución.
Cuando la reparación de estas unidades, hay siempre varias variables a considerar. Primera visita para ver lo que ocurrió por última vez con la unidad, como hicieron los hijos juegan con videojuegos, ¿la electricidad salir debido al mal tiempo. Usted puede ver que hay muchas posibilidades, pero vamos a concentrarnos en lo que se produjo el pasado a la unidad. Una vez que determinemos lo ocurrido el pasado, podemos identificar la causa real del problema. La causa real puede estar asociada con problemas de proyección, las versiones anteriores (tubo de imagen), la interferencia de los dispositivos en las cercanías, e incluso una radio encendida y situada muy cerca de su unidad. Esto es normalmente conocido como interferencia electromagnética a la electrónica y es muy común el error que usted ha proporcionado hoy. Por favor, seguir buscando algo externo a la unidad antes de ver los componentes internos. He estado trabajando en estas mucho tiempo así que siéntete libre de seguir conmigo.
Jan 24, 2011 | LG Studioworks 552V 15" CRT Monitor
AL PRENDER LA CAMARA CANON A 560, ME INDICA ERROR DE OBJETO REINICIAR CAMARA,,AGRADECERE SU AYUDA....
fui a tomar una foto prendi la camara y me aparecio ERROR DE OBJETIVO LA CAMARA SE APAGARA AUTOMATICAMENTE REINICIAR LA CAMARA no se como reiniciarla porfavor nesesito arreglarla graciasssssssssssssssssss
Nov 14, 2010 | Canon PowerShot A560 Digital Camera
I am tryng to find a USB driver for sony DSC-S750 cyber-shot camera
Al conectar a mi PC con windows XP no reconoce la cámara DSC-S750, favor ayudar como puedo descargar las fotos.
SAludos,
Jaime ariveljh@cablemodem.com.ec
Mar 07, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Sony DSC-W90
NECESITO LOS DRIVERS PARA DESCARGAR LAS FOTOS DE MI CARA A LA COMPUTADORA
Jul 12, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Drivers para W vista, modelo dsb c310
por favor necesito que me ayuden con la instalación de la cámara web d-link c310 en mi laptop modelo Sony VAIO VGN-N350FE con Windows Vista, ya que me sale como que no es compatible, por favor indiquenme como descarlos?.
saludos,
Angela
May 29, 2008 | D-Link VisualStream DSB-C310 Webcam
Sony Cyber-shot  DSC-T100 Digital Camera Logo
196 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
