Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
No picture only audio
Hello, for some reason I have only audio, no picture. The guide for cable will appear and work, the menu will appear and work but I do not have tv picture I have a 46 inch aquos E77 . Can you help me
  • Sharp Master
  • 736 Answers
The problem is not with your television at all because you are able to see images on it. If there were a problem with your television you would not be able to see the guide for cable or the menu. Try turning off your cable box and unplugging your cable box for 30 full seconds to reboot it. If this does not work call the cable company customer service representatives for support.
Posted on May 05, 2010
Has audio, but why did screen go black?
since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Feb 09, 2016 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
Hello! I have a Sharp Liquid Crystal TV (37" display) and my menu options, specially the picture menu, is fixed. can you help me "unlock" it? Model # LC-37G4U
If the AVC System is switched on but it does not appear to be operating correctly, it may need resetting. In this case, press RESET, shown in the diagram, lightly with the end of a ballpoint pen or other pointed object. This will reset the System as shown below. • AV MODE resets to STANDARD • TV channel returns to initial channel setting (Air:2ch, Cable:1 or 2ch) • Twin picture resets to normal • Audio setting initializes • Dolby virtual resets to Off • Image position initializes
http://electro-medical.blogspot.com/
Nov 07, 2015 | Sharp Televison & Video
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
Sep 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HDMI sound is not working. I recently upgraded my laptop to one which has a HDMI output. When I connect it the picture works fine, but there is no audio...I have checked all audio settings on the laptop,...
The picture appear in the TV?So better check the plugging of HDMI cable or please try anather HDMI cable to find if the problem is in the cable.Then try it again the setting of the TV.Check the menu of the TV and set it to pc mode.
Jul 04, 2011 | Televison & Video
Hitachi P50H401 With Audio But No Picture
it works for me !!! just unplug the plug, wait 3 min. and plug again !!! it's all !!!
Aug 14, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Audio is working, no picture
you have either a defcetive signal pwb, FMT pwb or light engine. Does the menus appear clear when you press menu?
May 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Sony receiver
change yellow cable and try.
Aug 01, 2008 | Sony STR-DG800 Receiver
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
64 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
