Question about Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt
The pump on my sprayer pulsates. It will go from
The pump on my 25 gal spot sprayer pulsates. It will go from 8 psi to 20 psi. I have checked hoses for blockage and found nothing. I have cleaned the screening system between the main hose and the pump. I have let it sit hooked up to the running ATV thinking that the psi needed to build up but it still pulsates. What do I need to do to even out the psi?
SOURCE: Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Posted on Jan 08, 2009
jj505
  • 195 Answers
SOURCE: fimco atv sprayer troubleshooting
Are tips clogged??
Posted on Mar 31, 2009
  • 63 Answers
SOURCE: LAWN SPRAYER PUMP WILL NOT SUCTION
Check the screen in the tank, it very well may be clogged.
Posted on May 03, 2009
  • 1810 Answers
SOURCE: Lost drain cap
well depending on the size you might be able to go to the local plumbing store 1 inch to 4 inch is easy for them larger might be a little harder smaller than 1 inck
it might be the same as an old wine cork use a boat drain plug in this case
Posted on Jul 25, 2009
  • 961 Answers
SOURCE: I have the follwoing R.L.Flowmaster products: R.L.
They sell the sprayers and parts at Home Depot, Walmart and other places. I am providing a link for you to look at:
http://www.rlflomaster.com/wherebuy.htm
You can click on the store logos and pick out what you want and, they have an 800 number to check stock.
Posted on Jun 12, 2011
Pumps
as soon as your finger is off the trigger
Jul 06, 2014 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
I oown a 1999 jeep grand cherokee laredo replaced front windshield wiper pump on resevoir but still no fluid to windshield and i can hear pump.what is my next step.
the hose going from pump to sprayer could be cloged or the sprayer it self is get small wire to unclog sprayer and check hose
Jan 19, 2011 | Jeep Grand Cherokee Cars & Trucks
Moultrie 25 gal spot sprayer for water sealer treatment
Yes, I've used pumpup hand sprayers to apply sealers. Is the sealer water-based? If not, cleaning up the sprayer afterwards could be a chore!
Mar 01, 2010 | Moultrie 25 Gal. Spot Sprayer
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is...
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Apr 29, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Sep 19, 2008 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt Logo
89 people viewed this question
Top Fimco Garden Experts
Jay Finke
Jay Finke
R.A. Ellis
R.A. Ellis
James Bayne
James Bayne
Level 1 Expert
Are you a Fimco Garden Expert? Answer questions, earn points and help others
