Question about Bunn-O-Matic Coffee Brewer GRW8
Water in heating tank is boiling. What part am i
Water in heating tank is boiling. What part am i looking for to fix it? Thanks!
    President:
  • 1,618 Answers
Sounds like you need a new thermostat.
Posted on May 06, 2010
My reserve coolant is boiling but its stay full ...why???
Might be mostly water. Check the gravity of the coolant, one of those little floaty ball things at walmart, $2, If it is not up to par with 50/50 coolant, fill it up or drain some of the water out. It is building up too much pressure and releasing the boiling stuff into the reserve tank, the cap could be bad, not tight, could be a blown head gasket, check this stuff out. Look for oil in the top of the radiator, steam out the exhaust, usually loses water though. Water boils at 220 and coolant 260 in a closed system, keep an eye on the temp gauge, do not let it over heat. It will be shot if it does. Hope this helps.
Jun 28, 2011 | Dodge Caravan Cars & Trucks
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
My gas water heater sometimes sounds like its perculating. Is this a problem?
It can be if it keeps boiling the water. Your tank will have a pressure relief valve with a copper pipe dropping down near the floor...is there signs of water coming out of the pipe? Be certain it is working by testing it...lift the lever in the center of the relief (Place a bucket under the pipe first to catch the water that will flow out). Over time these valves can rust up and not work.
In the worst case, boiling the water causes steam build up in the tank which is under pressure. Enough steam can cause the tank to rupture and that is a bad thing.
I am not certain but you probably need a new temperature probe if the tank is over heating the water inside.
Dec 16, 2009 | Water Heaters
2001 Hyundai Accent. Heating and stalls
If the water tends to keep going down then there has to be a leak somewhere. Try also looking at the hose coming from the overflow tank and see if the hose might be kinked. You might also be blowing antifreeze out the tailpipe. Take a look and if there is bluish white smoke then you have confirmed that theory,
Jun 10, 2009 | 2000 Hyundai Accent
1989 acura is over heating
Your water pump is more than likely bad.
Apr 03, 2009 | 1989 Acura Legend
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Water Boiling in tank
Unplug the machine and remove the top. You will find a little box with a knob or a "T" on it, this is the thermostat. Just turn it down a little, put the top back on and plug it back it.
Nov 10, 2008 | Coffee Makers & Espresso Machines
Bunn VP-17 Coffee Maker
I would suggest descaling the unit, or replacing your thermostat.
A defective thermostat would not cut out the heater after the water is boiled, excessive scale would render the thermostat ineffective, but not to the extent you describe.
Hope this helps.
Oct 15, 2008 | Bunn CDBCP35 Automatic Brewer with 1...
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Bunn-O-Matic Coffee Brewer GRW8 Logo
186 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
