Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Dont have a manual how do u connect the hose to it
  • Bissell Bob May 11, 2010
    model number ?
  • 438 Answers
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furnituredont have a manual how do u connect the hose to it - 2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of redont have a manual how do u connect the hose to it - c8d927f.jpg and
remove lid.
by sliding it straight up.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleadont have a manual how do u connect the hose to it - b95cee8.jpgtion”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.dont have a manual how do u connect the hose to it - 2_bing.giffull suction, it is important that
the recovery tank lid is properlyReverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Posted on May 07, 2010
  • jevka Aug 15, 2011
    Thank you for pictures,they HELPED a lot!!!!!!!
How do i put panel G back in aplace if I took it all the way out
Posted on Aug 27, 2010
How to connect hose and wand?I don't see any place to connect hose?
Here's a download for PDF file that is the owners manual. Check page 8.
http://www.dirtdevil.com/manuals/?id=83831cab-2807-439b-811d-52aab2fd84ee
Apr 15, 2011 | Dirt Devil Featherlite Bagless Vacuum...
I do not know how to use the upholstery part to work
hi,
the owners manual is here at this link,
http://www.hoover.com/pdfs/manuals/F5807.pdf
I believe for you to work the upholstery tool the suction tank lid must come off, and the center channel there has to come out for the hose to go into, and then replace the suction tank lid again.
there should also be a second water hose to connect midway down the left side of the unit there little square push/pop out lever. the water hose will connect there and you should be good to go from there. Refer to the manual for the exact directions tho.
Nov 04, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I hooked up a hose to my Whirlpool dehumidifier for continuous drain and returned the bucket like the manual states. The bucket continues to fill and shut off. Model AD25DSS1 Serial Q1123013
Hi, check to make sure the drain hole connection on the Dehumidifer's reservoir, that you have the hose hooked to, isn't plugged.
Also, you might want to see if the hose connection on the reservoir, still has the "knock out plug" still in place. Look at the hose connection on the reservoir, and if you can't see through it, or put a screwdriver through it, you need to punch it out the middle with a screwdriver. Open up the hole as much as you can so it will drain into and through your hose.
Check your hose also, as it might be plugged, disconnect it and blow through one end to make sure the water can flow through it.
Those are the only three things that could be preventing it from draining out the reservoir, through the hose connection, and through the hose to your drain
Take care
Jul 18, 2010 | Vacuums
My girlfriend took all the hoses loose when
You can down load a schematics from Bissell at Bissell.com
Nov 26, 2009 | Bissell 8910 ProHeat Clear View Upright...
Need pics of bissel hose assembly
Just what the doctor ordered:
http://c.managemyhome.com/mmh/answers/Answers.action#l4q145526
This is not my website, you should thank the guy that made this. It took me a few days of searching to find it.
Nov 13, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How to remove attachment hose to unplug
The vacuum to the dirt cup, whether from the floor, or from the tools comes solely thru the hose. You need to check the hose for internal obstructions/blockage, from the open end all the way to the entry to the dirt cup. Here is the link to the Product Manual: http://www.hoover.com/pdfs/manuals/U5172900.pdf
I recall the hose connects to the back of the unit with a 1/4 turn lock. so try to turn the hose collar at that connection 1/4 turn counterclockwise, then pull it off. If any other qustions, let me know.
Oct 16, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
How do you connect the stair and upholstery hose to the hoover steam vac
You can download your manual at Hoover.com under Service and Support - Download Manuals. It's acutally very easy to connect: With cleaner unplugged, open the hose connection port on the top of the suction nozzle (much easier to just follow the pictures than to figure out from my description) and plug in the short hose end. Plug the solution tube into its connection port on the side of the lower unit (in front of the wheel). You'll also want to check out the instructions for cleanup.
Oct 04, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
I dont know where to connect the hoses
assuming you dont have the manual, you should try to google " manual for kirby G4" and you should see it there. you also have the option of downloading the manual in PDF format, to be opened with adobe reader, which can be acquired from http://www.adobe.com
Sep 24, 2009 | Kirby G4 Bagged Upright Vacuum
Where does other end of hose go
You're quite right . . . the manual doesn't show where the other end of the hose goes, which frustrated me as well. I finally found another pic of the cleaner (I think it may have been the one on the box) which revealed the answer. If you're facing the rear of the machine, there is a plastic "hose clip" on the right side of the machine (it looks like the letter "c"), and the "loose end" of the hose is snapped into place in that holder - it doesn't actually connect into an aperture (that end of the hose is just to place the little furniture brush on, if you use it). Once in place, the hose will actually kind of overlap itself and be held firmly in place against the side of the machine. Hope that helps - I too am not a fan of manuals that leave obvious questions unanswered.
Jun 15, 2009 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
932 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
