Question about Acer Computers & Internet
I put a new processor and i get no signal to my moitor
  • brownhero May 05, 2010
    acer aspire 5100 desktop the new processor is am amd athlon 2 2.9 ghz dual core processor if that is wrong can u tell me what kind a snould use
  • GCSmithACL May 11, 2010
    Likely your computer is not compatible with that processor, but to clarify, can you list the model of your computer and the processor you are attempting to install?
    Problem Solver:
  • 7 Answers
You should use an AMD Athlon64x2 4000+/4400+/4800+/5000+/5200+. You are trying to usehttp://www.newegg.com/product/product.aspx?Item=N82E16819103687 if I am not mistaken, which would not be compatible according tohttp://support.acer.com/acerpanam/desktop/0000/Acer/AspireL5100/AspireL5100sp2.shtml
Posted on May 05, 2010
How to fix a no signal monitor ?
If you have a known-good video card and a known-good VGA cable connected, another possibility is that the monitor is defective
Jan 15, 2013 | Dell Dimension C521 PC Desktop
No signal screen on moitor m3641
This message you get when your computer does not send a video signal on to the monitor..If ti seams to start and the fan is working ..check the cables to be proper inserted (the vga cable ..the one with protection screws on ) ..and if all is in place than it may be the video card to blame ..
If you have a pci or agp card installed ..other than the on board video card ..use that ..cause if you plugged it in the on board card ..it will have no signal as long as the pci card is inserted..If the agp/pci one is not working ..and you do have a on-board card ..remove the one in the slot ..and use the on board one until you will get a new card
let me know what you have managed to do ..
Dec 17, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
The computer shuts down after 10 to 30 min..I have already change the fan.
When computers shut down like this they are getting the signal from the motherboard. This is most likely a thermal shutdown signal from the processor. When you changed the fan, did you clean the processor off and apply a small thin layer of thermal paste? The processor may not be cooling properly or the motherboard is getting a bad signal from the processor's thermal circuit. Try new thermal paste on the processor and then go through the board again and make sure everything is in its place. Also, leave the side panel off and see if the system stays running, this will aid in the cooling. Let us know if it works, if not we may have more ideas to help.
Aug 25, 2010 | Computers & Internet
No signal imput i cleaned the video card ram and prosseser but one of the prongs was bent on the prosseser i bent it back but still get no signal
why it is bent? have you removed it at put it back? maybe when you try to put back your processor on the motherboard you place not the exact way. you don't need to pull out the processor, all you need to do is replace either RAM on VC, if does not work try to have a Mboard, if not work now its that the time to change your processor, or buy a new one..
Mar 04, 2010 | HP w1907 LCD Monitor
My flat panel moitor displays RGB no signal. I
If the other monitor has no signal as well, this proved the video card is faulty and needs to be replaced.
Dec 03, 2009 | Gateway Computers & Internet
New processor doesnt seem to be compatible with my Mobo?
You have to go to the foxconn website and check the specs for the board that you have. It will list the processors that are compatible. You have to get the right socket config too
Jul 05, 2009 | Foxconn Computers & Internet
Algerian-47
you could try removing power lead then remove battery from m/b for 5 mins this will reset bios back to maufacturers settings then replace battery and power then try boot up if no luck then change motherboard
Jul 01, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
No signal to moitor, good graphics bd and cable
It sounds like you have a bad motherboard on the PC where you are getting no video.
May 26, 2009 | ASUS Computers & Internet
Monitor saying no signal
check the Pins in the monitors serial port and make sure all are straight 15 of em
Jun 03, 2008 | Computers & Internet
Monitor shows no signal
ur monitor is "not" the problem... you have problem in ur PC..
solutions:
check loose graphic card
remove ram. put them back again/...
Feb 11, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
