Question about LG Art Cool LA121CNP wall/window Air Conditioner
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
My window ac 1.5ton cut off with a **** at 28 deg temp with in 3 minute .room temp is 31 deg. ac is 2years old and i bring in good working condition from my brother. it was kept idle for 1 year
Posted on May 09, 2010
  • 26 Answers
Either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
Posted on May 06, 2010
I set it for 70 degrees and at 78 degrees to 80 degrees the compressor will turn on for about a minute and turn off. If I move the machine or walk by it the compressor will turn on for a minute.???
there are a couple things you need to rule out. first look at the capacitor in the outside unit. big round cylinder in the compartment above where the copper lines enter the unit out side. if it is round on top its bad. or it could judt be week and need a boot with a hard farf kit. check the compressor to see if its overtly hot or the coils are very dirty restricting the air pull or circulation which will not only keep it from reaching temp but it will burn freon and being short on gas will cause the same thing symptom.
May 19, 2016 | AMERICAN COMFORT ACW300C 10,000 BTU...
My LG Model LP0910WNRY2 will not get cold even though the compressor turns on
check the outside and see if its blowing cold air out of condensor otherwise low on freon.
Jun 28, 2014 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
WONT START
1) test the outlet wall, try to put some lamp for to see if there are voltage
2) reset the c. breaker or blown fuse replace
3) test the power cord
4) try again. if the problem persist you must test the following a) wiring break or open b) thermostat c) compressor d) overload relais e) selector switch for open f) control board
God bless you . see the diagram attached.
Jun 22, 2012 | LG LW1010ER 10,000 BTU Window Air...
We have a LG model lwhd1009r. We cleaned out the unit and the coils are still freezing up and not cooling. We turn the the fan on and it thaws right away, but as soon as you turn on the compressor it...
there are 2 possiblities on this . 1 the indoor fan is running to slow you need to run it at hihg . or the unit is low on charge. Try running it on high fan and see if that does not solve the problem also close any vnets on the unit that say fresh air or outside air. when its really humide you don't need to bring in more. Let me know hope this help ... Jon
Aug 07, 2011 | LG LWHD1009R Air Conditioner
LG 10,000 btu air conditioner
I just bought the LG 10000 btu window model... I am having the same exact problem.. it feels like the air is not even on.. I am having someone look at it on Mon. I have a feeling the whole unit is defective. But it could be the thermostat needs to be replaced. Sucks 300 dollar brand new AC and it doesnt work!! Good luck. I will never buy LG again.
May 24, 2009 | LG Electronic Window Air Conditioner
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Unit doesn't turn on at all. Used to work and just quit
pls check power supply then check the unit switch (selector)
Apr 22, 2009 | Goldstar M1004R 10 000 Btu Window Air...
Lg 10000 btu ac wall unit
if you remove the front cover you should see a little sensor with a wire. you need to make sure it has not fallen off its bracket or came off form the evaporator. if it looks to be ok and mounted correctly, you may have a bad sensor and it is not able to tell the temp and not shut the unit down. also to on very hot and humid days even though you have it set to energy saver it senses it still needs to run. If you turn the thermostat up when its on the energy saver will it shut off? and if you do the same on the regular setting will the comressor shut off and the fan stay running? Let me know and I can go from there. Thanks
Aug 05, 2007 | LG Electronic Window Air Conditioner
LG Art Cool LA121CNP wall/window Air Conditioner Logo
574 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
