Question about Maytag MER5775Q Electric Kitchen Range
Can not work automatic clean cycle on Maytag range
I have a free standing Maytag electric range.I bought house with stove in it.There are no instructions and I do not know how the self clean mode works.I can not find a model number on the range. HELP Thanks Carole
  • Maytag Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on May 14, 2010
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have this stove in a house I just bought. Now how do I use the oven????
get the model # usually on the frame of the stove down where you open the drawer or around the oven cavity. then once you have the model contact an appliance parts store in your area with the model # and they should be able to get you some instructions or an owner's manual.
Oct 04, 2009 | Maytag Gemini 30" Self-Cleaning...
Burned on stain on burner will not come clean using cleaner and the blade
There are some very effective commercial products available. One of the most highly rated is Cerama-Bryte, but BE SURE TO FOLLOW THE DIRECTIONS CAREFULLY....as once it dries it is impossible to remove!!!!! Work in small areas, rub consistently.
As well, mr. clean magic eraser also has worked magic on my mothers stove over the past few years also.
If you wish to stay away from the store-bought chemical....soaking the spots with water and ammonia OR vinegar..(not both) and elbow grease. As well....the razor blade in combo with the liquid.
Be sure to rank me.....please....especially if this Fix-ya`s....
Nov 07, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Stove cleaning
The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
Jul 05, 2008 | Kitchen Ranges
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Maytag gemini gas stove
on the oval window of my gas stove, maytag it says 5 Ab my oven won't work because of this
Oct 29, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5775Q Electric Kitchen Range Logo
249 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
