Question about Ricoh Aficio CL3500N Laser Printer
Error code SC471
The Ricoh Aficio CL3500n printer is giving the error code SC471. Does any one have a possible solution? IKON is wanting to send a techician to service the printer. The printer prints nice color documents then stops and displays the code: SC471. Any help would be great!! Thanks.
  • 1,110 Answers
SC471 is a Transfer Belt HP error. The transfer belt does not lift in the rear. The rear cam (G060 3894) slips past its locking tab on the square stepped shaft and slips off the side.
The fix: reposition the rear transfer belt lift cam to lock the tab into the square shaft. Secure the locking tab with a tie wrap.
Now this is the solution if you know what you are doing on this printer. I can not even begin to tell you in this forum how to dis-assemble the printer to get the transfer belt unit out and effect this repair. IKON is pretty pricy on labor. I would see if there is an independant guy locally that can do it. Inexpensive repair that I would charge $90 or less for. If you HAVE to call IKON then just make sure they do not try to tell you that you have to replace the transfer belt unit. This repair is all that is needed 90% of the time.
Good Luck and Thank You for using Fixya.
Posted on May 05, 2010
Testimonial: "fantastic advice and thanks for all the information. That was my exact problem. Thanks for the information. Much appreciated. "
Aficio cl3500n error code SC411, the printer comes up with a error code, all button function locked
I remember a discussion on this code in an old thread somewhere. The agreed solution was to replace the whole transfer roller assembly because of a broken contact terminal in the discharge plate housing. I'd probably try that before a high-voltage board.3
For more help visit cbr tech solutions
Nov 15, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
Error 441 Ricoh Aficio CL3500N Laser printer... what should I do?
Hi
It is EVELOPER MOTOT LOCKED.
I can only gave you a link to look at but it only have the error codes.
http://grou.ps/www_diycopymachines_com/talks/20700
Feb 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Can ricoh aficio cl3500n use glossy paper that is
Ricoh recommends heavier paper be run from the
bypass tray 16lb to 53 lbs are the recommended weights
Sep 25, 2009 | Ricoh Aficio CL3500N Laser Printer
Error message replace/ supply
If you open an internet connection and an the top address bar type in the IP address you will see you printer and be able to see the supply that needs changing
Jan 05, 2009 | Ricoh Aficio CL3500N Laser Printer
Printer was off for two weeks and now error sc471
SC471 means: Belt tension unit cam error. Even though the belt tension unit tires to return to its home position several times, the home position sensor is not activated.
Possible Causes:
Defective transfer belt unit.
Defective transfer belt tension unit.
CN25 Pin 3 on the engine board is unable to send a signal.
Suggested fixes:
Replace the transfer belt unit.
Replace the engine control board.
Replace the transfer belt tension unit.
I would start by opening it up and inspecting the transfer belt and associated parts. Pull them out and re-seat them. Look for broken wires, stripped gears, gunk in the works. Clean it, then put it back together and test.
If you aren't up to it, it is probably time to call the repair man.
Dec 16, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL3500N error code SC581
Q1 - Possibly, I have not seen an SC581 error before. Usually using too much power would give you something like an SC240 error "Power Supply Excessive". So it depends on the extent of the damage. You could also have to replace the main board, motors, etc.
Q2 - You will have to pull back the feeder tray, remove the back panel, there is a cover over the main board and the power supply is below it and fairly easy to get to. But if other components were damaged it could be a much more involved repair.
Jul 24, 2008 | Ricoh Aficio CL3500N Laser Printer
Stops Printing Entire Page After Around 50 sheets
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Jun 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
937 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
