Question about LG VOYAGER VX10000 Cellular Phone
My touch screen is acting funny.
So everything was just fine with my phone until today. i actually have it sitting right next to me and its just in its own world. i will go to press the end button, then it will go to my shortcuts menu,go to pictures,then click on my first picture. i also cant click the icons on the bottom of the touch screen on the main menu. i have calibrated it several times, but it continues to have the same response. what do i do?
SOURCE: Lg Dare phone
Leslie,
I had purchased and am currently using the LG dare. The issue that I had with the icons apprearing on my main screen was that I was accidentally holding down and dragging the icons from my shortcut menu to the main screen. The easiest way to get rid of the icons from the main screen is to hold down the icon and drag it to the little arrow for the shortcut menu, and it should dissapear.( I just did it on mine so it should wok for you).
If that doesn't work, open you shortcuts menu, hit the set button and remove the icon from the shorcut menu (this should remove it from the main screen as well.)
good luck!
Posted on Dec 19, 2008
if you dont have an arrow in the upper mid right side of your main screen. go to call settings>display settings> turn on shortcut bin.
the arrow will appear, drag and drop it on the arrow and then go turn that shortcut bin arrow off if you dont want it there.
Posted on Jan 26, 2009
  • 8404 Answers
SOURCE: Shortcut menu button on VX11000.
Your phone may need professional adjustment. Please take your device to the professional repair shop located within most Verizon sales areas.
While there, ask them to update your software.
Thanks for posting your question at FixYa.com
Posted on Dec 13, 2009
SOURCE: My LG Dare phone has worked great ...until today.
i think i have the same problem i also pressed reset button and now it doesn't allow me to do any thing please can someone help
Posted on May 23, 2010
  • 131 Answers
SOURCE: my phone's touch screen isn't reading my touches
hope this helps try calibrating the screen
Posted on May 28, 2010
Touch screen not working
Could be SIM card incompatiblies problems,many SIM cards causes trouble afterward because of written softwares by to many companies.Tries the exact SIM card by that phone manufacture should or could solved this problems
Dec 14, 2012 | Pantech Breakout
I have dropped my phone and now the touch screen doesn't work how do i reset my phone when the touch screen doesn;t work
if your phone's touch screen has not developed any cracks, it could have damaged the touch interface internally, i would suggest getting your phone checked at nearest Samsung authorized service centre
May 09, 2011 | Samsung Wave S8500 Smartphone
Car wont start in cold idles funny for a moment, then is fine .The heat dont act right gets hot going down the road cools off when sitting at idle.
i hate to be the bearer of bad news but it sounds like a head gasket failure.usually occurs in cyl 2 ond or 3 in these engines (1.8L).car sits and engine cools coolant leaks into cylinder and when started runs with amiss until coolant burns out of cylinder and conversely air gets in cooling system,system gets low and you have poor heat esp at idle.have your mechanic confirm but these engines are becoming notorious for this.
Feb 02, 2011 | 2002 Nissan Sentra
My samsung impression dropped in water and touch screen broke
I also dropped my Samsung Impression in the toilet, I immediately took the phone took the protective case off, took the battery cover off, and took the battery and my SIM card out and towel dried it as best as I could. Then I sat it on the floor next to my fan and let it dry until I got to my grandparents a little while later and I put it in a bowl of rice, completely covered the phone and battery with rice and left it sit overnight in the rice and all of the next day, so far i've had it on about 20 minutes and have had no problems with it so far, another solution is to sit it in the sun, to further dry it out. Water damage will void warranties on your phone and battery and your provider will know instantly if the damage was water related when they take your battery cover off, there is a small square sticker that when dry and hasn't touched water should be white, but as soon as it comes into contact with water it turns red, there is also one of these stickers on the battery. My stickers were red and after sitting in the rice they look like they got lighter in color considerably, I don't know if that is really possible but appearance wise it looks that way. I hope this helps anyone who has had this problem. Good Luck!
Nov 15, 2009 | Samsung SGH-A877 Impression Cell Phone
The external screen on my lg env touch is partially gray
this happened to me today actually. yeah apparently its from there being pressure on the phone screen. its not going to go away, and mine ended up taking the entire front screen by the end of the day. if its under warranty, they will give you a new one i think. but when i went in today, without phone insurance, of course they are not going to give you a new one for free. unless its still under warranty
Nov 03, 2009 | LG enV Touch VX11000 Cell Phone
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Feb 05, 2009 | Nintendo DS Lite Console
Messed up Image
You need to replace both of the convergence ICs. They are both STK392-570 you can get replacement ICs at the following link and they provide free instalation instructions with pictures on how to replace the ICs. Here is the link.
http://servicemanuals.vstore.ca/
Jul 08, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Dell Inspiron 700m screen acting up
try to uninstall and install the the display drivers / graphics card drivers.. it should help you.
Feb 20, 2008 | Dell Inspiron 700M Notebook
Messed up Image
bad connection on convergence amps or need to replace them
Oct 11, 2007 | Mitsubishi VS-50805 50" Rear Projection...
LG VOYAGER VX10000 Cellular Phone Logo
134 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
