Question about Whirlpool Dryers
GEW9878PW1 Whirlpool dryer will start and heat up when start button is depressed, but stopps immediately after letting go of the start button.
  • 958 Answers
SOURCE: Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
SolutionGuy
  • 331 Answers
SOURCE: while push to start button is depressed, dryer works...
I must respectfully disagree with micbeth1981, sorry. This symptom screams Even Heat Control board. So Carlos, if you choose to replace the switch as advised, go for it. It's alot cheaper than the EHC board for sure, but you'll still be replacing a part that doesn't need replacing.
Generally speaking, when these boards fail, there are burn marks on the PC board that are easy to see. Not all the time, but more times than not. Follow this link to see a breakdown, #13 in the drawing is the component that's failed.
So if you want to visually inspect it, follow these steps. All you need is a Phillips screwdriver, a 1/4" socket/nut driver and a flashlight.
UNPLUG THE DRYER!!!!
Remove the 2 end cap trim panels on the console by pulling on them from the top (they are just snapped in place). This exposes a phillips screw on both sides, remove these. Behind the dryer control panel, you'll see two 1/4" screws on either side, remove these. Now pull the control panel toward you and lift at the same time.
You should be able now to rotate the entire control panel so you can access the back panel. Remove any screws there and set that panel aside. This will expose the EHC board (it's the PC board mounted in a white plastic bracket). Use a flashlight and inspect the board, see any burns? If so this verifies the failure. If not? Well, I told you that it doesn't burn every time... It's still a failed board.
If you followed the link above, you'd have seen that the part number for this board is 3402605. If you have an appliance parts retailer nearby, you can pick one up there for ~$130, or you can order one online from Sears (the above link) or just shop around for the best price.
Another note... Occassionally, when these boards blow out, it also takes the thermister with it. Which means that it'll have to be replaced as well. Here's the link for it just in case you need it after replacing the board.
micbeth1081, seriously... no disrespect intended.
SG
Posted on Mar 24, 2009
localwonder
  • 6784 Answers
SOURCE: dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
Posted on May 21, 2009
SOURCE: whirlpool gas dryer no heat
One the terminals on the flame sensor fell off. II guess this is a common problem. relaced the sensor and
I'm back to drying clothes.
Posted on Oct 05, 2009
pride applia
  • 232 Answers
SOURCE: My Kenmore dryer "Start" button does not stay depressed.
a complete model # from inside the door would be helpful, on wost dryers when this occures the motor is packed with lint so the sentrifisle switch cant move from the pastion to the run or the switch on the motor itself is bad, the run windings in the motor could be bad. some of thethe more complicated dryers have a relay on their control board than burns out. try blowing out the motor with compressed air or the blow end of a shop vac use the skinney attat. to concentrate air
Posted on Dec 08, 2009
I have a quiet pak 2 Kenmore. When I depress the start button the drum works but there is no heat. I stops workin when I take my finger off the start button. Model 110.73932102
I looked up the model number. You have a 90 series dryer made by whirlpool. You need to take it apart and clean it up, cheack all limits and safetys for continuity. I beleive you have a bad motor If the drum turns and the belt is not broken when you release you button it stops that is either the start switch or the motor.
Feb 05, 2014 | Kenmore Dryers
My dryer wont stay on if I push the start button it turns on and heats up but once I let go of the button it sits of rite away.
what's the brand name and model number,if it's a kenmore or whirlpool and says even heat with the lint filter inside most likely a bad even heat computer board or the motor relay both are up in the top console,if it's a g.e. you have a broken belt switch,there's a switch down next to the motor and belt pulley,it's just a cherry switch,it has a button that sticks out of the switch that hits the belt pulley,if the belt breaks then the dryer will only run when the start button is pushed in but the switch can break causing the same problem,also on the newer whirlpool it also can be a broken belt,good luck with your dryer
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 10, 2013 | Dryers
Hello My drier has stoppped warming the clothes, it is still turning - but no heat. Whirlpool Gold Model no 3RLEC 864 6K 08 Thanks Rheinallt Williams
dear Rheinallt , the problem is one of two things either the thermostat or the element itself . Try the drier on different heat settings to see if it heats at all . If it does - then its the thermostat . if it doesn`t then it most probably is the element . Depending upon where you live it would probably be more economical to buy a new one .
Aug 13, 2011 | Whirlpool Dryers
GE commercial coin op dryer only runs when start button is depressed. The second you let off the buton the dryer stops.
hows the timer unit on doing when you push on it the timer is suppose to start..
Apr 15, 2011 | GE Dryers
Whirlpool model GEW9878PW1 overheats on all settings, including Air. Sensor or the temperature switch?
you will need to remove the rear cover of the dryer,then the flat tube on the right slightly at an angle there will be 2 thermostats on the left side of this tube,unplug the wires off of each of them and get replacements for both components,one is a cycling switch and the other is a high-limit thermostat,replace both due to the excess heat has probably ruined both components
Nov 10, 2010 | Whirlpool Dryers
Whirlpool gas dryer model number lgr6848aw0 is working but not heating. Please advise you opinon on what the problem might be. Thank you in advance for your assistance in this matter.
It is probably the limit switch which is located near the burner. It has 2 wires that terminate on a small disk about the size of a dime. There is a button located in the middle. Depress the button firmly. This should take care of it unless it is the gas valve.
Apr 17, 2009 | Dryers
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
