Goodmans gtv42p6 plasma tv the tv fires up giving vs voltage but ther is no picture or on sreen graphics although you can tell the screen is lit
4 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Posted on Jun 24, 2008
SOURCE: SAMSUNG PS42D4S PLASMA TV HAS
I had the same problem here but I notice that one of the compoent on the power supply board is melted slightly. Suspect that it might be the cause. the compoent have a symbol of transformer and is grey in color...(look like a cap) ...compoent number is L48
Posted on Sep 14, 2008
  • 93 Answers
SOURCE: vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Posted on Nov 22, 2008
Samsung plasma TV sound but no picture
Both Vs and Va voltage should be checked. As far as audio is OK, the possibility of main digital board fault.
Sep 01, 2016 | Samsung Televison & Video
LG TV 60PZ550 black screen no pic or sound green lit flashing it has back lite
LG 60PZ550 Plasma - No Sound, No Picture - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Sep 15, 2013 - 20 posts - ‎4 authors
LG 60PZ550 Plasma - No Sound, No Picture Troubleshooting TVs and Video Sources. ... I see no change in the screen at any point (no glow). With the rear cover ... I've worked with some electronics in the past, but am new to TV's. I'm sure .... Multimeter on DC 1000V, red on (+) marked, black on (-) marked. Lg 3d plasma 60pz550 i've got sound but no picture
Jul 18, 2014
LG 60PZ550 color issue - Badcaps Forums
Jun 9, 2014
Purple/Pink Lines / Postering on plasma LG 60PZ550
May 29, 2014
LG Plasma 60pz550 has strange greenish rainbow ...
Jan 20, 2014
More results from www.badcaps.net
Jan 10, 2016 | LG 60PZ550 3D Plasma TV
Running machines broken
Dear Sir:
Please adjust, clean very well, and tigh the connector from Reed switch see the diagram attached.
2) Tight the flexible cable from keypads + connector from display board vs lower board.
After your fix it RUN the software calibration for diagnosis +trouble
sincerely. God bless you
Apr 20, 2012 | Exercise & Fitness
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
LG 50PG25 Plasma TV, black screen sound still works.
this faint picture issue is usually caused by a bad z sustain board. it is the smaller scan board on the right side of the tv when viewed from the back. it has some large cables that energize the plasma panel, dont confuse with the y sustain which has the tiny ribbon cables that address each line of the picture.
there should be a # on the board indicating the part number, plug it into a search engine to find parts.
this could also be a low voltage or something else, check the Vs and Va voltages and confirm theyre correct with the ones listed on the sticker inside the tv. Be careful this is dangerous and you can get shocked if you not familliar. The heatsinks can be energized and shock you , exercise caution. if you order a z sus board, make sure you can return if it doesn't fix. I'd say 95% chance its a z sus
May 21, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Samsung plasma red fuzz on black screen
Most likey its a bad panel, you can try adjusting VS voltage on Y main board, if this is to complex you will need a tech
Aug 09, 2009 | Philips 42PF9630A 42 in. Plasma Television
TO GET THE DIFFRENT BETWEEN LCD VS PLASMA
LCD
LCD stands for liquid crystal display. These types of displays have been around for awhile and are commonly used with computers. One reason for their big popularity is the ability to produces a better picture than CRT monitors but also being much thinner.
Pro’s
  • Low Energy Consumption – LCD monitors use very low amounts of power. This is why it is very commonly used in battery powered devices.
  • LCD screens also reduce the amount of glare on the screen which can be very beneficial if your TV is in a room with lots of light.
  • If an image is left on the screen too long, LCD screens are less likely to experience the image being burned into the screen. If this does occur, it’s easier to repair than other types of TV’s.
Con’s
  • The viewing angle of an LCD TV is typically not as great as Plasma but the difference is not great enough to make a huge difference.
  • LCD TV’s can sometimes get dead pixels which aren’t typically covered under warranty. Although they are very small, they can become very annoying.
  • Brightness levels aren’t as great as Plasma and it’s not possible to display darks quite as dark.
Plasma
Plasma technology hasn’t been as widely used as LCD in previous years but has become very popular in large HDTV’s. Although they have historically been more expensive than LCD TV’s, they are becoming more comparable in price.
Pro’s
  • Brightness and color are the major advantages of Plasma TV’s. They produce rich colors along with very deep blacks.
  • Their wide viewing angles allow more people to be able to watch TV comfortably.
  • The pixels of Plasma TV’s are lit individually unlike LCD screens. Because of this feature, the pixels can be completely turned off to display truck black colors.
Con’s
  • The lifespan of a Plasma TV is typically shorter than other types of TV’s. The lifespan can be extended by turning down the brightness of the screen.
  • Plasma TV’s are more susceptible to screen burn-in where an image is “burnt” onto the screen when left on the screen too long such as a network logo in the bottom right corner of the screen.
  • Plasma TV’s require a panel of glass to cover it. This glass can reflect light and make it difficult to see the picture. If placed in a dark room, this typically isn’t an issue.
Jun 09, 2009 | LG Televison & Video
How you cann repair a broken plasma tv with out replacement parts
The tv plays fine my sreen is cracked on my Sony 42inch screen can some one help me.
May 13, 2008 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
