Question about Dell Dimension E510 PC Desktop
The desktop will come up with just the background. If I open the Task Manager the hard drive will start up and then the icons will appear. I have similar problems on shut down. The screen message will say "savings settings" and lock up. I have a fairly new hard drive, but it worked great for months before I started having these problems.
    New Friend:
  • 10 Answers
Hello:
This is primarily a request for more info and clarification, however, I have provided info on a couple of ways to start the troubleshooting process.
Could you clarify what operating system and version you are running on your PC? Do you currently have an anti-virus product installed, is it current, and do you perform regular scans? If this is in reference to a Windows computer, has your computer been connecting to the internet? If so, are you running safety features available on your browser(s) (ie popup blocker, phishing filter, others) - and what browser are you using primarily?
By the symptom description, I am guessing you are running Windows (although to give you detailed, step-by-step solutions, I will need to know what version of Windows). With activity such as this that you did not initiate either by restarting the computer, or by installing something, or if Windows update has not recently installed new updates, then the first place to look is at possible infection by virus or some other type of malware.
If you know how to boot into safe mode, give that a try. (on XP, Vista, Win 7: as system boots, immediately after the splash screen for the BIOS, and BEFORE the word "Windows" appears, start hitting F8 until a menu of choices appears, and choose "Safe Mode").
Check your antivirus product (if one is installed) to see what the current version is, and whether or not it has been recently updated. Also, check to see when the last scan of the entire system took place. If you are able to get around in your antivirus product without major restrictions while in safe mode, you should go ahead and run a complete scan of your hard drive (or drives), to ensure both that your antivirus product is working properly, and to find out whether or not you have any type of malware on the system. If you are certain that your antivirus product is the most up-to-date version, that it updates daily or weekly and scans the entire hard drive at least once per week, then you can temporarily rule this out and move on to checking the Event Viewer, explained below.
Check your event viewer to see if it is available while in safe mode, - if so, you want to look for any recent events under "System", "Application", or "Security", that appear suspicious to you, occurred immediately prior to system popping up with "saving settings" msg.,or during the process of saving the settings and logging you off. You are looking for any information which might indicate the file that is starting the process of saving settings / logging off / shutting down, or just plain locking up.
To get to the computer management console & event viewer in Win Vista and Win 7:
Click "Start", look in the right column of the menu for "Computer" and RIGHT-click, then choose "Manage" ("Computer" should have a little shield attached to the icon, indicating you need to be logged in as Administrator, or have admin privileges - if you are asked if you would like to allow the program to make changes, etc, click "YES" - Whether or not you see that question, or can access the program with admin privileges, depends on how your User Access Control or UAC is set up); This will open the Computer Management Console.
To get to the computer management console & event viewer in Windows XP:
Assuming you have a "My Computer" icon on the desktop that you can see, right-click on "My Computer" and click "Manage". If you cannot see the icon, but can see the "start" button, you can pull up the start menu, then right click on "my computer" from within the menu, again choosing "manage" to open the console.
In XP/Vista/7, In the left column, look for "Event Viewer" and expand it. How many or which items are listed there depend on your OS version and your configuration, but generally all should be able to see "Application" "Security" and "System" among the items listed. When you click each item listed under event viewer in left column, such as "Application", another list of items will appear in the in the right column. Double click any event listed and a new popup window opens with details of the event. Read the details listed from today (if the issue has occurred on your system today), and see if you can find in the information what program or file is causing this issue.
It sounds as though the system is attempting to log you off, but never completes and shows a log in screen. you may or may not be able to read much info in Safe Mode, but there could be some key info there as to what's causing your problem.
Again, I can only give you limited answers due to the lack of info; so if your problem persists, please respond with more information, and try to keep note of exactly what you do / what computer does / and any popup or system messages that appear (what the system messages say, as completely as possible). Then we can take further steps to troubleshoot.
Hope this info helps! Please post back and let us know what you find out (even if it is that you cannot get to safe mode). Thanks and best of luck
Posted on May 05, 2010
    Problem Solver:
  • 7 Answers
I would reinstall your operating system.
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Had a virus got rid off it but now screen is white and cannot do anything with it
Lost start button and icons
Are you saying there are no icons on yourdesktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press andHold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click theImage Name column to get them in alphabetical order. Look forexplore.exe, if you see it listed click it once to highlight it then click theEnd Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the leftand select the option New Task (Run). When the Create New Task window openstype: explorer.exe and press OK. Your items will start populating andappearing on the desktop.
Mar 29, 2012 | Computers & Internet
I have an HP1110n....It acts like it is booting up, but I only see my screen background pic. No icons show up. The disk spins and is doing something, but it won't display ANY icons ! Help !
This happens when Explorer (the file manager - the program that makes all the files visible on the screen) doesn't starts at boot. Press Alt + Ctrl + Del to open Task Manager. Click File, click Run and type explorer. Click OK and the icons and the taskbar will appear. If it doesn't start or it's faulty in any way you will have to reinstall Windows.
Jul 31, 2011 | HP Pavilion a1110n (PX743AA) PC Desktop
Welcome screen comes up but when I click on user name it goes to desktop screen background with no icons
This can be fixed..
Press and holt Control+Alt keys and then press Del key one...
Then you need to select the option task manager..
In task manager select file at the top...
Under file select new task and type explore.exe in lower case and push enter..
You must be able to see the start menu and the desktop icon...
If you still dont find the desktop icon - right on desktop and select show all desktop icons...
The problem should be fixed...
Sep 28, 2010 | Dell Inspiron Mini 10 Notebook
Acer Aspire One D250-1042 shows desktop wallpaper but won't load
Start by logging on as the Administrator so you can check the Task Manager and find out what Application or Process is monopolizing the system.
If the system is still unresponsive boot into Safe Mode. (Press F8 before the Windows startup screen appears.) If everything is fine in Safe Mode type MSCONFIG at the Command Prompt and start disabling features until you find the culprit.
Last resort, buy or borrow an external USB CD/DVD drive and use it to reinstall Windows.
Important: Reinstalling will ERASE the hard drive.
If this helps please vote for my solution.
Jan 19, 2010 | Acer Aspire One PC Notebook
I HAVE A WINDOW XP HOME EDITION AND WHEN I START MY COMPUTER THE ONLY THING THAT COMES UP IS THE BACKGROUND. THERE ARE NO ICONS OR A BAR AT BOTTOM OF SCREEN.
the icons and the bar(task bar) at the bottom of the screen are enabled by the explorer.exe file
it starts automatically but in your case it is not starting
to start it when your computer starts and comes at the desktop, press alt+ctrl+delete button at the same time to bring up the task manager
when you do this a task manager shows up in a window
in task manager window click on file, it will be located on the top left portion on task manager
now click on "new task(run)"
this opens another window, in that window type
"explorer"
without the quotes "" and press enter
this will bring you icons and task bar at the bottom of the screen
Sep 29, 2009 | Computers & Internet
ThinkPad T60 Desktop Not Restored After Hibernation/Standby
there is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
Jan 01, 2009 | IBM ThinkPad T22 2647 Notebook
Cannot see my desktop
Please try these steps to solve your problem:
1) Press Ctrl+Alt+Del to run the Task Manager
2) Click on "File" on the Task Manager upper menu
3) Click on "New Task (Run)" option, Run window should appear
4) Type "explorer" without the quote, on the Run window
5) Your start menu and icon on desktop should now appears
hope it helps :D
Apr 29, 2008 | ASUS A9RP Notebook
Blank desktop, no start button
open task manger > applicatiins tab > selct new task> type explorer then ok then the desktop will coome uo
Dec 22, 2007 | Northgate STAC2217L (Bundle) PC Desktop
Dell Dimension E510 PC Desktop Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
