Question about Boss Chaos C3000D Car Audio Amplifier
It powers up, all indicator ligts are on, makes a sound like its warming up, and then theres nothing, does not put out at all
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Time to upgrade to a BETTER amp. lol
Posted on May 06, 2010
RED LIGT KEEP BLINKING ON TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 18, 2015 | Televison & Video
Grenn ligt blinking will not work
Sep 12, 2014 | Element ELC-HS321 32 in. LCD TV
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Radio not working
hi ther can you help just bought the tristar was working put it off then later put it on and nothing on the top board one of the components is only soldered by one leg don't know if this is problem also when power is put through rig noticed some smoke so put it off straigt away any thought
Dec 13, 2013 | PIAA 2004 Mercedes-Benz E-Class - All...
GE Microwave has no power
Sounds terminal. Could be the control panel but maybe cheaper to purchase a new microwave.
Jun 26, 2017 | GE JVM1790SK Convection/Microwave Oven
My temp reads 195, after the car warms up and the engine is under load it sounds like its overheating slightly. also the engine light comes on indicating a problem with cooling system. everything new...
there is a sensor in the resivor bottle that malfunctions alot and all engines used in that vehichle make a ticking sound under load that is a rod knock nothing to worry about but to be safe check you fluid level.
Apr 07, 2009 | 2001 GMC Jimmy
96 ford explorer no power no crank no anything
Sounds like a connection problem/error. When you replaced the starter solenoid, do you remember how many wires you disconnected and reconnected?
Was there any indication ( sparks, etc) of accidentally causing a short when you replaced the solenoid?
Your initial problem of no start but hearing the click sound is almost a sure fire indication that the starter is NG. If the solenoid clicks, that means that it is applying 12 volts to the starter.
hope this helps Good luck Loringh
Nov 08, 2008 | 1996 Ford Explorer
Acer TravelMate 290 PC Notebook not starting
I believe these are BIOS indicators on some type of motherboards This could be a motherboard or memory problem. What happens if you remove some or all memory?
Sep 24, 2007 | Acer TravelMate 290 Notebook
Fter power switch put on it show blank screen and no sound only battery and power indicator is on but hard drive indicator is off. does that is a cause or some hardware problem?
it's possibly a hardware problem but you should make sure it isn't a software problem by putting in your system restore cd and restoring the DLL that you deleted, it could be an important system file. If it is a hardware problem, the first thing to try is taking out your memory and sticking it back in place, make sure it's clean and put it in there tight.
Jun 25, 2007 | Sony VAIO VGN-SZ460N/C Notebook
Boss Chaos C3000D Car Audio Amplifier Logo
55 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
