Question about Liquid Video A170E101 Monitor
Monitor flashes 7 or 8 separate colors
Turned on monitor today and it wont respond to tower and just flashes full screens of different colors. Will only turn on or off. Does not respond to any other commands, computer plugged in or not
  • 4,889 Answers
Your monitor's inverter board is a toast you will have to replace it.. Post back if you have experience in electronics and you wanna try it yourself..
Posted on Mar 26, 2008
SOURCE:
Computer screen going staticky randomly during use, bright flashing colors.
Do a hard disk check. I would bet your hard drive is going on you. Make sure you back up everything. The other thing to check is your video card. Much easier to deal with on a tower than a laptop.
Jan 29, 2014 | Dell E228WFP LCD Monitor
Dell HP Pavilion screen scrambled
Either your monitor died or your video card/chip died. Test your tower with a different monitor or test your monitor with a different tower.
Aug 25, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
My monitor is not responding. I have a blank screen and my power led is flashing green, none of the front monitor buttons are responding, not even to turn of power. Cannot access menu as I have blank,...
Hi Cat, You can try removing the data cable of your monitor, the one connecting to the back of the tower/computer. If there are no issues on the monitor, normally you will be getting the power self test which is indicated by three vertical colors on the screen (Red, BLue, Green). If you dont see the power self test, it may be a problem with the monitor. YOu may want to try using a different monitor to isolate issue if available
Oct 27, 2010 | Acer AL1912 19" LCD Monitor
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Cant figure out color issue with computer.
Well...it's a Dell and even when it's well...it's still a Dell.
Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
Good luck with your Delllll...
May 14, 2009 | Dell E176FP 17" LCD Monitor
Hp pavilion a705w Light flashed in front and back on and off
Try a different monitor with your PC. If it does the same thing then you know the problem is with your PC. Also connect your PC to a different monitor. If it works OK then your monitor is bad. Does it beep at startup? Describe beep codes and someone on this website will decipher them for you. This might help to diagnose the problem.
Jan 12, 2009 | HP Pavilion a705w PC Desktop
Possible monitor or graphics card malfunction
The monitor is bad. The flashing is telling you that something inside the monitor has gone out. If it is still under warranty they should either fix your monitor or give you a replacement. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | Computers & Internet
Monitor flashes primary colors
Your monitor has disco fever and will have to be shot in a midnight ritual in Palm Springs. Or, you will have to replace a diac circuit linking the display, power control, and power supply grounds (or possibly an overvolt protector of some sort in the power supply.) I don't know why for this kind of error the designer couldn't just put a message on the OSD in some random human language.
Nov 21, 2007 | Acer AL1711 17" LCD Monitor
Liquid Video A170E101 Monitor Logo
303 people viewed this question
Top Liquid Video Computers & Internet Experts
Ekse
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
