Question about Sony VAIO VGN-TX670P/B Notebook
How do I remove keyboard of vgn-tx670P? - Sony VAIO VGN-TX670P/B Notebook
    Scholar:
  • 62 Answers
If I recall correctly, there are eight screws (maybe nine?) that need to be removed from the bottom of the machine, then the keyboard gets pushed down toward the front of the computer just enough to clear four tabs at the top. Then lift up, push toward the screen to clear four tabs at the bottom. Turn the keyboard upside-down to reveal the cable underneath. Flip up the latch and remove the cable from the system board.
Posted on May 06, 2010
Testimonial: "Excellent suggestion. Thanks."
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Blue tooth and wireless LAN does not install after installing windows XP sp3
Problem with a Sony Vaio. It seems one of the updates put entries in my registry to start a Vaio Lan Manager with Windows.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Check these keys to see if any kind of a 3rd party Lan Manager is running. If so, delete the entries and reboot.
Feb 28, 2011 | Sony VGN-TX670P/B: VGN-TX670 PM...
I'm forget my sony vaio vgn-tx670p bios password??
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Jan 06, 2011 | Sony VAIO VGN-TX670P/B Notebook
I'm having the dreaded 100% cpu usage.Would a new hard drive help?
if the cpu usage rides at over 90% constantly u need a newer faster cpu
Feb 25, 2010 | Sony VAIO VGN-TX670P/B Notebook
When you press power the light goes on for two sec and thats it nothing happens after
Probably going to sleep or hibernate. Sony is famous for making this default. Change your power setting in the control panel
Oct 10, 2009 | Sony VAIO VGN-TX670P/B Notebook
How to open case on VAIO VGN-TX670P
under the keyboard there is a screw. you have to open the keyboard, there is a lock near the speaker, you will neat a very thin flathead screw driver. near the key F1 F5 F12 and insert. open that and you see what i mean
Mar 26, 2009 | Sony VAIO® VGN-TX670PB PC Notebook
How the ?#$% do you get into the case on these?
you'll find that there are usually 2 to 3 smaller screws, which hold that top down. Look right above keyboard, for small, sometimes, color or arrow identified screws. that should get you there.
Mar 19, 2008 | Sony VAIO VGN-TX670P/B Notebook
Sony VAIO VGN-TX670P/B Notebook Logo
274 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
