Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Clicking noise behind fridge
Hi...
Noticed your response regarding a problem similar to one that I'm encountering. You stated that one would need a new "start system for compressor".
is this something that I can replace myself or not? if so, where can i find the part and what should I expect to pay?
  • 6 more comments
  • Anonymous Apr 11, 2008
    I had the same problem. It made that noise for a week then the frig stop working. It was the motherboard and I didn't have to pay. I found on the afterwards there is a recall on GE motherboards.
  • lolacoco Jul 28, 2008
    Is this freidg under a recall, if you have any info would you please send it to me. I have the same problem.
    thanks in advance
    joseph
  • Anonymous Aug 08, 2008
    Im also having the clicking sound come from my Fridge, if you look you can see a fan trying to spin in the freezer, it has gotton progressively worse.
  • joantw Nov 21, 2008
    Clicking noise behind the refrigerator which seems to be coming from
    behind a metal cover panel on the right side (facing back of the refrigerator).
    Present for a couple of weeks, then freezer stopped working...now
    refrigerator is not working either.
  • Anonymous Dec 19, 2008
    i have the same problem as joantw's.
  • yyyzhang Dec 30, 2008
    I have the same problem. A technician came and said it's from the control board.
  • venus163 Jan 13, 2009
    i having the same problem . clicking noise and now stop working. is this in recall.
  • mothraa Jan 28, 2009
    same problem, awaiting service person. fridge is out of warranty tho, so we'll see if they fix for free.
I have a PSC23NG refrigerator. I called (800) 386-1215, pressed 3, and spoke to GE Consumer Relations.<br /> <br /> I told her what I was experiencing with the unit and the symptoms seemed to make the main board issue. Within 10 minutes she had ordered it and set a next day service call.<br /> <br /> Way to go GE and stand behind the product. I wish I had been notified BEFORE it failed but the call was QUICK, PROFESSIONAL, and the rep was sincerely doing everything she could to get us a repair.<br /> <br /> Pleasently pleased.<!-- from fixya rte -->
Posted on Aug 16, 2010
  • moorerental Sep 30, 2010
    I have a Model # GSS22IFRF BB, Ser # DH250165. I had the same problems, starting with the dispensers not working
Plastic Liner Models
Serial # ZH - RL
Dec 05 - Aug 06
Metal Liner
Serial # MH2 - AL2
Jul 05 - Jan 06
DSF25MG PSI23NS BSS25JFR
Bottom Mount
Full Door
Serial # TH0 - ML0
Oct 05 - Jul 06
DSS25MG PSI23SG BSS25JSR GBS20 DSS25MS PSS23MG DSS25JFP GBS22 GSL25LG PSS23MS GSH22JFR GDL20 GSS23LG PSS23NG GSH22JSR GDS20 GSS23LS PSS23NS GSH22UFR PDF22 GSS25LG PSS23SG GSH25JFR PDS20 GSS25LS PSS26MG GSH25JSR PDS22 GSS25MS PSS26MS GSH25UFR PDW22 GSW25LS PSS26NG GSL22JFR SDL20 PCF23MG PSS26NH GSL25IFR PCF23NG PSS26NS GSL25JFR
PCF23NH PSS26SG GSS20DBP PCT23SG PSS26SH GSS20IBP PCT23SH PSS27NG GSS20IEP PIT23SG PSS27NS GSS22IBP PSC23MG PSS27SG GSS22IFR PSC23MS PSS29NG GSS22JER PSC23NG PSS29NH GSS25IFR PSC23NH PSS29NS GSS25JER
PSC23NS PSS29SG HSM25GFR
Bottom Mount
French Door
Serial # HH0 - ML0
May 05 - Jul 06
PSC23SG PSS29SH HSS25GFP PFS22 PSC23SH PST26NG SSH25KFR PSF23MG PST26SG PSF23NG PST26SH PSF26MG PST27SG PSF26NG PST29NH PSF26NH PSW26MS PSF29NG PSW26SG PSF29NH PWT26SG PSH29NH SSL27RG PSI23MG ZFSB26D PSI23NG
Posted on Dec 13, 2008
    Problem Solver:
  • 5 Answers
Contact GE and notify them of the problem. Also let them know that you have located numerous other cases of the problem online of people with the same problem. They will set up a service call and will cover the cost of the parts.
Posted on Aug 03, 2008
How do i figure out if my appliance is on the recall list? If you could paste a link that'd be great. Thanks.
Posted on Jun 13, 2008
Fridge not getting cold, set at coldest setting. bottom Freezer is cold though.
Hi.
The problem can be a defective defrost system. The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter.
A test on the defrost system can be done by performing a complete defrost manually (remove food and leave power disconnected overnight). If the fridge restarts working after defrost, then problem was the defrost system. In that case the problem may return after few days or weeks, meaning that one part in the defrost system is faulty.Parts must be tested.
If the defrost makes no change, then there is a different problem. The damper ventilation system , the temperature control or the refrigerant gas pressure may be the problem. When the problem is one of these faults you get the compressor is running regularly, but will stay on most of the time.
If the motor is humming and clicking most of the time, but not properly starting, then the problem is usually the starter relay/capacitor. Relay and capacitors can be replaced to fix the problem.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar on your model.
Regards.
Aug 06, 2011 | Amana Refrigerators
Tip
I have a similar problem the fridge seems to work but the freezer isnt, the fan...
If you have a refrigerator or a freezer that is not working like it once did then you are looking to get it working again. The reasons why he unit may not be working properly can be many. One of the reasons may be that the refrigeration unit that is the cooling power of the unit is slowly leaking refrigerant.
If the refrigeration unit is leaking very slowly the loss of charge may be so subtle that you will not notice it till the unit basically stops cooling completely. Then all of a sudden you realize that you have a problem. If this is your problem, you will notice that the compressor is running, the circulating fan(s) will be running, and the condenser fan is running. Everything appears to be perfectly normal, but you are not getting the cooling from the unit that you need.
If you have this situation then there is often not that much that you can do. To recharge the unit you will need to find a technician that is certified to handle refrigerants. The system which is charged and sealed at the factory will have to be tapped and the proper refrigerant added to the unit. Even then you still have a system that is leaking and the fix will only be temporary. Sometimes the leak point will be obvious, other times the leak may be very difficult to find. Most of the time, the leak will be next to impossible to find and repair.
Bottom line here is that you will have to make some hard decisions about the repair of a leaking refrigerator or freezer. If you get refrigerant added to your unit it will be a temporary fix. If you can find the leak and it is repairable, you will have a bill for that repair also. That bill may be more then the unit is worth if it is a basic model or an older model. In many cases the purchase of a new unit may be the best option.
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4326586-new_refrigerator_refrigerator_depth
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
on Jun 25, 2011 | Refrigerators
My fridge is making a clicking noise (like a car turn-signal) and the digital display in the fridge is out
The clicking is from the main control board relays clicking off and on . The part number you need is WR55X10656 . This board is located on the back , behind an 9X10 inch aluminum panel . It controls the digital display along with all other operational parts of the fridge .
Aug 21, 2009 | Refrigerators
Our Freezer section bust into flames
Could you take pictures and allow me to post your story. This is interesting and I believe it will be information for all to know and be concerned. Thanks, Sea Breeze appliancepartsse@gmail.com
seabreezehvac@yahoo.com
Mar 31, 2009 | Smeg FA561X Side by Side Refrigerator
F&P E442B - Knocking/cracking noise
It is probably the buildup of ice around the condensor (located behind white panel in freezer). I chekcked mine and the ice had pushed the panel oajar and the condensor unit was out of place too. All due to the excess buildup of ice. I removed the ice tonight.. will tell you if this fixes noise problem. Also our fridge was not cooling ..freezer ok.. hope this fixes this problem too- otherwise i'll test the fan (located behind panel in freezer compartment.
Mar 09, 2009 | Fisher and Paykel Active Smart E522B...
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Clicking Fridge
I used to have a whirlpool fridge, they are the ones who make kenmore too. It used to make a loud thud noise. It was the compressor turning off. sometimes it was loud enough to wake me up at night. It did this for years and I never had any problems with it. when I purchased a larger fridge I sold it to a friend and its still working today. If you can tolerate the noise I wouldn't worry about it unless it starts giving you trouble.
Nov 01, 2007 | Refrigerators
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
1,824 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
