Question about Samsung HL-R5656W 56" DLP HDTV
I have a 2 inch wide dim (colorless) strip down the left side of my HL-R5656W. It happened after a move. Could I have jostled anything? How do I fix this?
  • 160 Answers
Yes you could have. Try 2 sources, cable, dvd, game system. If the issue is with any 2 then it is the tv and it will have to be adjusted by a repair center. If it's only one source then it could just be the actual source that the issue is with. You can also push the menu button and if the line is over the menu it's for sure the tv.
Posted on May 06, 2010
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Mar 31, 2013 | Minolta EP1030/1030F CS/PRO Copier
Where is "fan #2" in Samsung dlp hl-r5656w?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).
My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
Jan 26, 2013 | Samsung HL-R5656W 56" DLP HDTV
Why do I get a series of dimples on the printout?
check the format of your documents, you have to clear the possible formats which could cause the colorless dimples
Nov 15, 2012 | Brother HL-4040CN Laser Printer
Vertical blue transparent line plasma
Check for loose or dusty flexible connectors. (Please take care to switch off TV and remove plug from the power outlet and discharge high voltage capacitors before you do anything on the PCB) Apply cleaning oil in connectors wherever possible and remove and reconnect it a few times. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Nakamichi VU50P 50 in. HD-Ready Plasma...
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Black strip 1.5 inches wide on right side of page
first, take drum unit out and make sure the blueish-purple colored plastic tab on top of drum is all the way to the left side. if thats not the culprit, then you are most likely looking at a bad contact image sensor or CIS.
hth,
ray
Apr 03, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Samsung HL R5067W Problem
You have a bad Light Tunnel in the Light engine, you can replace the engine, or try to replace the tunnel.
Jul 31, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R5656W 56" DLP HDTV Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
