Question about Car Audio & Video
Need to know which wire is power - Car Audio & Video
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Yellow & red
Posted on May 06, 2010
Need factory wireing for car stero in isuzu rodeo
WHY, IF A NEW RADIO IS BEEN INSTALLED, JUST PURCHASE A RADIO PIG TAIL FROM THE RADIO PLACE FROM ISUZU TO WHAT EVER SONNY PANASONIC WHAT EVER., IF THE WIRES WERE CUT, FIND THE RED WIRE, POWER KEY ON.
BLACK WIRE GROUND.
YELLOW WIRE POWER WHEN LIGHTS ARE ON.
BLUE WIRE POWER ANTENNA
THE REST IS EASY, YOU CAN MATCH COLORS LIKE GRAY WIRE AND GRAY WITH A TRACE OF BLACK.
GREEN WIRE AND A GREEN WITH A TRACE, YOU GET WHAT I'M SAYING RIGHT, IF YOU NEED TO KNOW MORE SPECIFIC LIKE R/F L/R L/F THEN GET A (AA OR AAA) BATTERY AND TOUCH WITH THE WIRES BOTH POLARITY'S YOU WELL HEAR THE SPEAKER MAKE SOME NOISE, THAT WAY YOU KNOW WERE THEY ARE LOCATED. BAT FIND THE POWERS AND GROUNDS FIRST.
May 24, 2014 | Isuzu Rodeo Cars & Trucks
Need a replacement, where do I get one?
If I understand correctly you have a 3-speed fan.
And you need a 3-speed replacement pull-chain-type switch
Lowes carries 3 speed fan switches in the light fixture department.
These switches have multiple wires.
At any given time, there is one-and-only-one wire that connects to power from wall switch.
Lets call this the Power wire.
As you pull the chain, the power passes through the switch and goes to one-and-only-one of the other wires.
The other wires connect to windings in the motor.
The different motor windings control fan speed.
The key to replacing the switch is recording where each wire went before you disconnect old switch.
Once you know which of these wires is the Power wire, then you can test other wires with a continuity tester.
You also know the pull-chain sequence is OFF - HIGH - Medium - Low
Mark wires in fan and mark wires on old switch.
Pull out old switch.
Use regular electrical tester to find which wire in the fan is the power wire (separate wires, turn on power and test each wire to metal part of fan)
Now test the switch wires.
The switch is out of the fan.
You marked the wires so you know which wire is power wire.
Put the continuity tester on the power wire.
Test power wire to each of the other wires.
Click the switch and test to each of the other wires. Mark which wire lights up continuity tester.
Click the switch and test again. Mark which wire lights up continuity tester.
Click again, until each wire is marked in the sequence.
When you click the switch and no wire lights up, then that is the Switch OFF position.
Do the same test on the new pull-chain switch.
Connect the wires to match your testing.
Oct 25, 2010 | Westinghouse Electric Westinghouse...
Need to find switch power wire 2006 explorer for fm modulator
Have you tried looking for an empty cavity in the fuse panel? Usually there will be one or more in there, just stick probe in there, and if no power, try turning key on, and if it lights up (test light) or shows power , use it. make sure you fuse wire though.
Dec 23, 2009 | 2006 Ford Explorer
Security Camera
it is important to know model and make or camera if you want a solution
Jul 09, 2009 | Home Security
I need a wiring legend for the Rampage BA200 sub woofer
Red - power
Black - ground
Blue - turn-on (switched 12 volt)
Green and Gray -- Hook to factory/aftermarket stereo for the signal.
Jan 14, 2009 | Car Audio & Video
Wiring on a Clarion
power wire is red,mem wire is yellow, dimmer will be orange or orange w/ white line in it, and the amp wire will be the one that shows 12volt power only in the on posision (blue) if it has two the other is for power ant.
Jan 12, 2009 | Clarion DRB2475
Need to know wirring diagrams
the red is your memory alwayse is a live wire. Yellow tells cd player to turn on and off, Black is your ground. the other ones are your speaker wires go to your doors. Also if you have a power antenna it is the blue wire with the white stripe. Hope this helps
Jan 10, 2009 | Car Audio & Video
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Wiring colors
You will need a voltmeter. Normally red is power, black i ground, yellow is memory power. the best way to know for sure is to use a voltmeter to test what each wire is recieving in power and when. If the key is off then the wire that has 12volts dc is for memory and the main power wire should be at 0volts dc. When the key is on that wire should have power now. the ground will be black on that car. Good luck.
Feb 20, 2008 | Car Audio & Video
Car Audio & Video Logo
111 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
