Question about Princeton Digital VL1916 19" LCD Monitor
I was given the VL1916 monitor w/out the power supply. Where can I buy it ? Thank you.
  • 11,361 Answers
Describe your (VL1916) 19" LCD
Did you try this monitor with another PC and already verify that the VGA cable is OK.
Common problem with Princeton monitors are due to bad DC filter capacitors in the power supply board, see example here:
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
Sep 10, 2011 | Princeton Digital VL1916 19" LCD Monitor
Service Manual with Schematics for Princeton VL1916 LCD Monitor
this issue might not be because of your Monitor. Anyway, I can only provide manual to this legacy product of princeton if you want...
Sep 06, 2007 | Princeton Digital VL1916 19" LCD Monitor
Princeton Digital (VL1916) 19" LCD
Try to decrease your screen resolution. see attach picture: or restart your computer then if windows xp booth press F8 then choose ENABLE VGA MODE. press enter. jimmyverdade_4.jpgjimmyverdade_5.jpgjimmyverdade_6.jpg
May 27, 2011 | Princeton Digital VL1916 19" LCD Monitor
VL1919 blue light flashes continuously, monitor does not turn on. . . even after DAYS of flashing. : (
That is the problem with the standby section of the power supply. A continuous flashing indicate a shorted component usually a small diode.
May 24, 2011 | Princeton Digital VL1916 19" LCD Monitor
LCD monitor produces excessive noise through
You may have bad filter capacitors in the power supply.
You need to open it up and inspect the inside, see some pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Princeton Digital VL1916 19" LCD Monitor
I have a Priaceton VL1916 moniter comes on for a very short time then goes dark
Look at the power supply for bad caps with bulging top first, common problems, post back what you see inside so we can guide you further, see example of failed PRINCETON monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | Computers & Internet
Hi my pc monitor keeps turning off & on, why and how do i fix it???
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | Princeton Digital VL1916 19" LCD Monitor
Princeton monitor, model # vl1916 Wont power on.
Hi, Billman11, maybe you can repair or maybe not. You need to tell me some stuff first. Need the approx age of the display. Next thing! Does the monitor have external power supply? (black box, sit on floor type) or internal (line cord to wall outlet, and other end to monitor) What exactly happens if monitor is connected to afully booted PC with known good vga output and u connect the flat screen lcd and push the power button? Is lcd panel still pitch black? no flicker or anything? Can you see the power on led indicator even?? From waht you already described it sounds like a Switch-Mode-Power-Supply failure. Each lcd monitor has 2 or 3 printed circuits inside under metal shields beneath the black plastic case covers. In your case, we will want to investigate the board that the line cord plugs into. That will be the smps board, or the little black box on the floor. If you want to try fixing this monitor you can get back to me at louie12fix on fixya or lmistyrel@ aol.com Yes, I'm a vet and spent a year on Kanghwa Do, Korea 67-68 Work for company that provides electronic hardware/software to the gaming industry and located northern Illinois. BYE for now.
Mar 31, 2009 | Princeton Digital VL1916 19" LCD Monitor
After a power outage, monitor won't turn on
Anytime there is an electrical surge the weakest part is the "Inverter" inside your monitor. It is two pencil size tubes that generates the DC power to the backlight of your monitor. Bring to repair shop and ask to look at the inverters. Once changed it will work fine
Don't forget to rate this solution.
Jan 21, 2009 | Princeton Digital VL1916 19" LCD Monitor
In my years of working on LCD's, your inverter (basically like a ballast in a flourscent lamp) is bad/going out. Crack open the case and look for a big pink and white wire going to a pcb (usually located under a shield) and remove it and check for puffed capacitors. If there are some change them and that usually fixes the problem. If there are no signs of anything wrong on the inverter, get the numbers off the pcb and google or ebay the numbers, usually youll find a replacement realitively fast.
Sep 15, 2007 | Princeton Digital VL1916 19" LCD Monitor
Princeton Digital VL1916 19" LCD Monitor Logo
183 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Fishlung
Level 1 Expert
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
