I can't put my computers speakers on correctly because i could attach my speakers they just don't work.what do i do?
  • 1 more comment
  • angelito10 Mar 26, 2008
    what do you think that i should do all about this pleassssssss helppppp me!
  • Anonymous May 09, 2008
    i have speakers for my compaq presario but i get no sound from anything.
  • eagle338
    eagle338 May 11, 2010
    Whats the brand of your speakers.. Model number as well please..
    Sergeant:
    Champion:
  • 329 Answers
Have you check your computer if there is a sound card for your speakers?
Posted on Mar 27, 2008
SOURCE:
My monitor speakers don't work, but I see an extra connection that has no wires attached is that for the for the speakers??
The monitor should have a wire that goes to the green colored input plug on the back of the PC.
Sep 07, 2011 | Soyo DYLM2286 Monitor
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
I have a set of logitech X-530 speaker for my computer with windows home 7, i have had the front left and front right speaker working properly, however now i cannot get any sound from any of the...
Try to disconnect the input connector of your speaker and touch the input jack of the unit if you hear a hazing sound it means your speakers are working properly but if you don't hear any sound your speakers are bad. Open the speaker unit and check the amplifier section of your unit. If you don't see any burned electronic component inside. Check the wiring of your unit.
To check if the audio of your computer is working. Plug in the input a headset if you hear a sound while you playing a music in your computer it means the audio of your computer is working good.
Jul 12, 2011 | Logitech X-530 Computer Speakers
I need a diagram showing how to connect the Digital Media Theater to the speakers and computer
i have found some posts on your speakers very nice anyway hope this helps
Just found an RCA to mono mini adapter and rca cable, plugged it in, and it works great. I notice a very slight difference in sound, for the better.
It's a digital cable, stereo/mono don't apply. It should be a single 75 ohm coaxial cable. Not a tip ring sleeve stereo cable. Any old RCA coax cable (with the appropriate 1/8 in. mini mono adapter) should work.
I attached a picture of the back, it is blurry, but you can at least see what it is. (top right jack)
May 07, 2011 | Boston Acoustics MediaTheater Computer...
I have compaq FLC presario speaker system and it doesnt work...want to get the correct software for it.....
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Mar 04, 2011 | HP Compaq Computer Speakers
I DON'T HEAR ANY SOUND. BUT SOMEONE HAS WORKED ON MY COMPUTER. HAD TO PUT IN MOTHER BOARD. IS THERE AN UPDATE I CAN DO?
also
hope this helps
don
Feb 27, 2011 | Polk Audio AMR50 Computer Speakers
Can not get speakers to work in the rear audio port of my tower..
also
you might check
hope this helps
don
Feb 23, 2011 | Cyber Acoustics CA-3080 Computer Speakers
Hi just bought these speakers and only the right and left work?? any suggestions??
you might have to select stereo speakers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
don
Feb 15, 2011 | Logitech X-530 Computer Speakers
The light wokes but the sound does not work
Do you have the speaker wires attached correctly? One should connect the left and right speakers, and the other should connect to the speaker audio port on your computer (should be the light green one).
Aug 12, 2010 | Dell A215 Computer Speakers
Open Questions:
CHARTER helpline phone {&$&{[email protected]*1O69} NuMbEr USA This CHARTER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 CHARTER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the CHARTER USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, CHARTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. CHARTER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact CHARTER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling CHARTER USA Calling CHARTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from CHARTER USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with CHARTER USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare CHARTER USA's phone numbers against each other. Contacting CHARTER USA in General While I8OO8O31O69 is CHARTER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach CHARTER USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact CHARTER USA.
Oct 17, 2019 | Best Computers & Internet
ROADRUNNER helpline phone {&$&{[email protected]*1O69} NuMbEr USA This ROADRUNNER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 ROADRUNNER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the ROADRUNNER USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, ROADRUNNER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ROADRUNNER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact ROADRUNNER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ROADRUNNER USA Calling ROADRUNNER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ROADRUNNER USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ROADRUNNER USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ROADRUNNER USA's phone numbers against each other. Contacting ROADRUNNER USA in General While I8OO8O31O69 is ROADRUNNER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ROADRUNNER USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ROADRUNNER USA.
SBCGLOBAL helpline phone {&$&{[email protected]*1O69} NuMbEr USA This SBCGLOBAL USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 SBCGLOBAL USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the SBCGLOBAL USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, SBCGLOBAL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SBCGLOBAL USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact SBCGLOBAL USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SBCGLOBAL USA Calling SBCGLOBAL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SBCGLOBAL USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SBCGLOBAL USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SBCGLOBAL USA's phone numbers against each other. Contacting SBCGLOBAL USA in General While I8OO8O31O69 is SBCGLOBAL USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SBCGLOBAL USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SBCGLOBAL USA.
Computers & Internet Logo
19 people viewed this question
Ekse
Alun Cox
