Question about Pitco Frialator SG14 Deep Fryer
Pilot blows out as soon as tempiture is reached
    Problem Solver:
  • 11 Answers
Try removing all electrical connections and polish all contact points (emery cloth) including screws. Also try tapping on the regulator, magnets may be sticking. Thermocouple for pilot may be defective.
Posted on May 13, 2010
How do I fix the pilot on a CFM Insta-Flame DV34 RN?
Typically, the thermo-couple reaches a certain temperature which sends a signal to the valve body telling it to allow the pilot to stay lit. The easy answer is to replace the thermo-couple. Or, you could just replace the entire pilot assembly to ensure all the parts are new.
May 07, 2014 | Home
Model # hwr08xc7 8000 btu. The air conditioner turns on but all it does is blow warm air no matter what setting i have it on.
you can take off the front cover and under the control panel, on newer units have a relay that the low voltage thermostat controls and by pass it. WARNING IT WILL NOT CYCLE NOW AND WILL NEED TO BE UN PLUGGED WHEN DESIRED TEMPITURE IS REACHED. IF NOT IT WILL BURN UP THE UNIT.. this not a 4 sure fix but can get you up and cooling 4 free, or if this doesn't fix it the unit might be junk.. hope this was of help..klick yes
Jul 25, 2011 | Haier HWR08XC7 Air Conditioner
Have Cozy heater model# CDV251A .Have spark , gas/but it will not light?
Be sure the control knob is set directly on the Pilot position. When you depress the knob, if it doesn't go all the way in (Bottoms out), release the knob and turn it a hair one way or the other, until you reach the point that it will bottom out when you push it in. If that doesn't solve the problem remove the front cover to expose the pilot assembly and blow out the pilot with compressed canned air (like you clean a computer with) and blow out the pilot tip. Any other dust or lint you see, clean that out too. Reassemble the cover and try lighting the pilot again.
Jan 26, 2011 | Cozy (W352E) Heater
Pilot light wont stay on. How do you adjust pilot flame? Pilot flame doesn't reach temperature sensor.
then the pilot is blocked needs cleaning out or try blowing it out with air , or undone pilot and remove pilot injector and clean it .
Nov 01, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Pilot is not heating thermalcoupler
You may have a dirty pilot orifice. Try this. Turn off the pilot by turning the control knob to off. Remove the front panel to get access to the pilot orifice. Use a can of compressed air with attached straw (the same stuff you use to clean computer keyboards) and blow out the pilot orifice, which is inside the pilot assembly where the pilot flame burns. Blow it out from the top and from the sides through the air holes. Then relight the pilot and see if that improves the flame size and color (blue) to heat the thermocouple. Douglas
Jul 26, 2010 | Bosch & Tankless LP Hot Water Heater
Pilot light goes out
Two things to check. Make sure you have continuity through the terminals on the high limit. Also make sure you have a good pilot flame and the pilot generator is supplying over 500 millivolts. It's either the high limit or the generator.
Tom
Jul 15, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot light goes out when burners kick on burnham
Get a toothbrush and clean the **** off the pilot, could be partially blocked. Change the safety thermocouple. Check the plenum for cracks. A cracked heat exchanger can cause this.
Nov 07, 2009 | Goodman GMS90703BXA Heater
Reddy Heater 125t won't restart on its own after first cycle.
Sounds like a bad thermostat! (A common problem with this model) replace and it should work again!
Jan 30, 2009 | Desa International RH125AT Utility Heater
Pitco Frialator SG14 Deep Fryer Logo
85 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
