Question about Atari Rollercoaster Tycoon 3: Soaked! Expansion Pack for Windows
I have just installed Soaked but it will not run, no autorun, or shortcut on desktop. I have Rollercoaster 3 installed and that works fine.
    Sniper:
  • 60 Answers
Try to start it in the cd file.. Go into you computer and go to ur cd drive and click on the disc name and find the file auto run..
Cheers.
Posted on May 09, 2010
My memory card is showing shortcuts inside.. all folder changed to shortcuts.. n i m unable to open this.. pls suggest me answer
This is one VIRUS. Please Scan that sandisk with any antivirus. just you can use Kaspersky.
The manual procedure to see all the fiels is:
1. Connect the USB drive
2. go to command prompt. Run-> cmd
3. goto sandisk drive
by default c:\> prompt appears. type the drive letter with colon.
c:\> E: (if E drive assigned to your sandisk)
you can see in mycomputer: drive letter may be e: or f:
4.After getting that drive as prompt. like e:\>
Then type these commands.
attrib -s -r -h *.* /s
attrib -s -r -h desktop.ini /s
attrib -s -r -h autorun.inf /s
del desktop.ini /s
del autorun.inf /s
rd recycled /s
rd recycler /s
rd $recycled /s
5. Then goto My computer. you will find the folders and shortcuts also
please remove the SHOTCUTS only...
This will helps you .,
Jun 17, 2011 | SanDisk 1GB microSD Memory Card
My Great Brain Robbery is old and says it works with Windows 95, Windows 3.1 & MacIntosh. I have Windows XP and can't seem to get it to setup. Any ideas?
1. Create a shortcut on the desktop for the setup/install program on the CD. 2. Right click in the shortcut you have created and select properties then click on the compatibility TAB at the top of the dialogue box. Tick the [Run this program in compatibility mode for] box and select windows 95. Then click [OK]. 3. Double click the Shortcut you just created and the program will install. 4. After it has finished installing find the shortcut it has created for the game and repeat step 2 for this new shortcut. It should now run in windows 95 mode.
Jan 09, 2010 | Davidson Pre-Algebra Math Blaster Mystery...
Fm 09 does not work any more !!!
This sounds like your shortcut is corrupt, try running it from the CD by exploring, then clicking on Autorun.
I hope this helps, let me know.
Steve :)
Jul 06, 2009 | Video Game Consoles & Games
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Java will not show my pictures in my Nav Bar scroll
try to reinstall your java and check well that your pc clean of virus and then be sure that no software working with your startup like autorun or ... extra. so 1- new java 2- check for a virus 3- go to microsoft windows update and make update for the end it will solve. if not run me.
Jan 05, 2009 | Microsoft Windows XP Professional
Have installed it but have no desktop icon so don't know where to go to use it
Dear
most of softwares have auto option to create shortcut to desktop and program menu.
but some of them dont have option to create shortcut to desktop. Then of that type of softwares what we do.. .follow these steps:
1..Find the root path of installed softwares generally c:\programm files\...
2. Find the running .exe file.
3. Right click on .exe files go "send to" then "desktop(create shortcut)"
Now u will find shortcut on ur desktop.
Hope this will usefull for u.
Oct 18, 2008 | Computers & Internet
Desktop icons lost
Sadly, there is no straightforward command you can use to recover them, but well, there are three ways, really, that you can get your icons back, depending on which ones were lost, that you are referring to. for this, I'm assuming you're running a more recent version of Windows.
----- For Windows XP ------
1) for recently deleted icons- check your Recycle bin, they could still be there.
2)for system-installed icons, such as My Computer, and Internet Explorer- you can recover these by going into your Display Properties (Start -> Control Panel -> Display). Select the Desktop tab, and click on Customize Desktop. Make sure the "General" tab is selected, then, under the "Desktop icons" section, tick off the icons you want to restore. click on "Ok" when you're finished, and Presto! those icons are up on your screen.
3)If the above two options don't work, you may have to add them manually ( a pain, I know). To add a shortcut in this fashion, right-click anywhere on the desktop, and select New -> Shortcut. you will have another window appear on your screen, asking you where the file you are making a shortcut to is located, and what you want to call it. follow the steps, and when you're finished, you should have a working icon. (another option would be to reinstall the software that made the icons, but that's also a pain in itself.).
----for windows vista ----
1) check the Recycle Bin (same procedure as Windows Xp, although, if your recycle bin option is deleted, then you have a problem that can be solved by using #2)
2) For system-installed shortcuts- follow This excellent tutorial.
3)Manually installing shortcuts- same as for XP.
Dec 17, 2007 | Computers & Internet
Quickverse 7.0 and vista
I tried the following and it works. I had several bad installs and this works. My guess is that the first steps are not necessary, but they won't hurt.
1. Insert the first CD and explore to find the autorun file. Right click and choose properties, and run it in compatability mode with Windows 98.
2. Right click again on the autorun file and choose to run it as administrator.
3. Follow all the regular steps for installation.
4. On the new shortcut, right click and choose properties, run in compatability mode with Windows 98.
5. Finally, right click on the shortcut icon and choose to run the file as administrator.
Good luck. It is a wonderful software I have had for ten years and used on a half dozen computers.
Nov 17, 2007 | Parsons QuickVerse 2005 Expanded Edition...
Atari Rollercoaster Tycoon 3: Soaked! Expansion Pack for Windows Logo
317 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
James Wishart
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
