Question about John Deere 2010 Tractor Basic Carburetor Repair Kit
Where can I get a new carb four 2010 john deere not rebuild .will not start when worm.
    President:
  • 1,627 Answers
You should be able to get a new carb from any john Deere dealer.You may want to check the tractor for fire when it's warm,you may have a coil breaking down when warm due to the oil has leaked out over the years.I would check to see if you have spark or not before buying a new carb.
Posted on May 05, 2010
Have a John Deere 11hp. Runs great for 5 minutes, mows fine too. Then is starts to miss and pop and will barely stay running with choke. Then it pops some more and acts like the safety was bumped and dies...
Hi Laurin:
Considering all that you have done, it is possible that you do have a bad condensor. If the consendor has a defective component that reacts to temperature, it may be that when cold, the correct function is happening, and as it warms up (the 5 minutes run time)
the expansion associated with the temperature change causes the malfunction.
Considering the relatively low cost, I'd be considering doing both the points and condensor.
Jul 01, 2015 | John Deere Garden
My john deere 2010 backfired twice now wont do anything when I turn the key I hear tumbleweeds
So it won't activate the starter motor either?
If so then sounds like a safety switch issue.
If starter goes and it just won't start, then sounds like your fuel got cut off - check the fuel cutout solenoid that some ride-ons have on the carb - follow its wire back to the ignition switch and look for shorts / breaks etc.
Jan 24, 2015 | John Deere 2010 Tractor Basic Carburetor...
Replaced fuel filter on my John Deere LA120 and now it smokes and will not go to full throttle any ideas on how to fix the problem?
you got dirt in your carb when you changed fuel filter you always have to clean fuel filter before you replace it have to rebuild carb now no choice rebuild it
Sep 09, 2014 | John Deere Garden
Whats causes my john deer 2010 gas to run onily with choke out ? Had carb rebuilt and tank cleaned. will low compression cause this?
i have seen about 4 of these have the solenoid on the bottom of the carb stuck closed was able to clean 3 out of the 4 there not cheap so try hard to clean it also had a few briggs engines have bad safety switches shut them off so check for power and ground
Jul 08, 2012 | John Deere 2010 Tractor Basic Carburetor...
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
14.5 horse I/C ohv with oil
sounds like the needle valve and seat in the carb is bad
Jun 02, 2012 | John Deere Garden
Our John Deere 160 lawn mower wont start. Installed new carb, fuel filter, battery. Has spark but wont turn over and run.
if the engine doesn't spin look at the starter if it has spark and a new carb is there power to the solenoid on the bottom of the carb does it fire on carb cleaner?
Apr 27, 2012 | John Deere Garden
My john deere lt133 i bought a couple days ago cut good a few times then wouldnt start checked the oil found gas had gotten in could this be from me not correctly turning on the mower and turning it off or...
If your JD has a float type carb, the problem lies in there as the float is bad or the needle stuck in the open position allowing gas into the crankcase via the cylinder. rebuild the carb and check the float to make sure there is no holein it causing it to sink. Needle and seat should be replaced and new one adjusted. Also you may want to change out the oil with the gas in it as it will destroy the bottom end of your motor if left mixed in.
Apr 12, 2012 | John Deere Garden
Riding mower does not seem to be getting gas
yeah.. the carb needs to be cleaned and rebuilt that is an easy job so if your a DIYer this will save you loads of money. just buy the rebuild kit..good luck
Apr 06, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere wont start gas is coming from the exhaust pipe
if it coming out from there then it's flooding sounds like the float is stuck open you will need to rebuild this carb and clean out all the small holes inside with a small blow gun or can of compressed air...good luck
Apr 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 2010 Tractor Basic Carburetor Repair Kit Logo
292 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
