Question about Craftsman 3/8" Corded Drill
I took apart a Craftsman 38 inch corded drill to fix the cord but need help putting the pieces back together. Is there some sort of diagram for Model 315.10510?
4 Suggested Answers
  • 31 Answers
SOURCE: craftsman 19.2v drill/driver lithium-ion model 315 119100 jammed
try reversing the chuck, if the gears have "climbed" over each other what ever you do will have to be backwards.does it feel locked from the gearbox or the back end? the brushes can also lock the shaft up.
otherwise faulty unit, send it back
Posted on Jan 06, 2010
goldenglove1
  • 144 Answers
SOURCE: I have an old 315-11441 Craftsman Drill. I took it
With these types of electric motors there is an armature, (the main brain of the motor) it has all the copper wiring wrapped around it and slides between two carbon brushes into the armature housing. If you took out the armature, there is sometimes a very thin peice of metal at the top of the armature which slides into the plastic housing above the armarture and creates a spring loaded "seat" for the armature, if this little shim looking thing fell out, you will need to find the old one. Without this tiny peice of metal the armature in the motor will have play in it causing the brushes to wear to one side or the other prematurely, the brushes have to wear evenly. Sometimes the brushes are spring loaded as well for a self-feed type deal. If these springs are missing the same thing will happen. Also one or both brushes could be in backwards. Check and make sure the brushes (black carbon and rectangular shaped) are positioned to support the spin of the armature. Lord, I hope this helps. I worked with small electronic motors over 15 years ago. I worked at the place for a few months, and didn't think I still remembered everything,
Posted on Aug 12, 2010
SOURCE: Craftsman Model #315.271690 3/8 Professional
How do you remove the chuck from a Craftsman Model #315.11441 3/8 vsr corded drill? Am trying to remove the chuck but I believe there is some type of a set screw or locking mechanism that needs to be undone. I can see a slotted screw head in the chuck Looking straight down on it but it is very tight and I don't want to break it or a screwdriver forcing it. Thanks for input. Bob
Posted on Sep 23, 2010
I need to replace a cord on an old Craftsman 1/2" drill
A lot of times B&D makes molded cords that work with Craftsman stuff. Look up a service center near you and take the cord in to see if they can match it up with something they have. (Take the drill in too.)
http://dewalt.com/Find-Service-Center.aspx
Apr 22, 2012 | Craftsman Drills
I have an old 315-11441 Craftsman Drill. I took it apart to fix the switch and in the process something must have shifted in or around the gearing. After putting back together when I power the drill I hear...
Aug 12, 2010 | Craftsman 3/8" Corded Drill
I have a Milwukee Drill - 1/2
http://www.ereplacementparts.com/
Sure it can be fixed. Here is a link that you can get a diagram and order parts. It is prob just the brushes.
Jun 02, 2010 | Craftsman 3/8" Corded Drill
Am trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like.thanks!
No pix or diagram, but you'll see a coil spring that provides the retracting function, plus one very small ball bearing that provides the holding function. The ball bearing sits on a dimple in the case and "lodges" itself in a groove in the top plate, so that whenever you rotate the case all the way around once, the ball bearing falls into the dimple and locks the two pieces together until you yank the cord. The cord just wraps around the case and there is enough friction between the cord and the case that as you pull/slide the cord, it winds the spring.
What happens most of the time is that the case/plate slips apart and the tension comes off, and/or the ball bearing drops out.
I took the plate off the case (a small phillips screw), rewound the spring a couple of turns, rewrapped the cable, very carefully put the ball bearing in the groove, and put the screw back in. It was difficult, and you should do it with tacky paper on your work surface because I dropped the ball bearing quite a few times.
Earlier in this column, someone said send it back in for warranty. almost worth it to do that, because the small pieces can be frustrating to deal with.
Apr 05, 2010 | Generic Memory Mini Retractable USB...
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
I need help putting the metal spring back in. i
Hey if you look at poulan starter rope there is a solution posted for how to re-wrap the spring. ( it's actually pretty quick and easy to do ).
Jul 02, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
Craftsman 3/8" Corded Drill Logo
151 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
