Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Epson printer problem
Hi fwadley
I have an epson rx425. It needed ink cartridge renewal which I completed, however the paper jam light keeps coming on and I keep getting asked to remove the paper, but there is nothing jammed in it that I can see. I have tried everything even uninstalling the printer then reinstalling. Can you help? Much obliged.
Chris
    Master:
    Sergeant:
  • 482 Answers
See if you can turn the printer upside down and shake it. sometimes the new ink is bad. go to epson.com and look around, you can call them. I would get the hand book for your printer and read it.
Posted on Mar 27, 2008
SOURCE:
Epson rx425 paper jam
The cartridge may have not been seated. You should never do what you did, it could damage the cart and it will leak ink into the printer.
Feb 01, 2014 | Epson Stylus RX425 Multifunction...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My r230 is having this trouble: the two red lights are blinking.
If the Ink Out light flashes, the printer is getting low on ink; if it is on solid, the printer is completely out of ink and you need to replace the cartridge; if it is flashing rapidly, the printer detected a print head unit or ink cartridge installation error. If the Paper Out light is on solid, you need to install paper in the printer; if it is flashing, the printer detected a paper jam. When both the Ink Out and Paper Out lights are on solid, the printer thinks that there is a carriage error; if both lights are flashing, there is a fatal error and the printer will need to be sent in for service Source(s): http://www.epson.com/cgi-bin/Store/suppo...
Mar 06, 2011 | Epson STYLUS R230 InkJet Photo Printer
Epson RX425 Ink Cartridge problem
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Jan 02, 2010 | Epson Stylus RX425 Multifunction...
Epson r230
Nov 02, 2009 | Office Equipment & Supplies
EPSON RX425 RED INK LIGHT STAYING ON
Try to find "EPSON RX425 Resetter Software" at google
Sep 06, 2009 | Epson Stylus RX425 Multifunction...
Epson RX420 has all lights flashing + E in the display, Have just changed ink cartridge and problem occured
OPEN SSC UTILITIES,DROP DOWN CONFIG BOX,SELECT RX420 MODEL,CLOSE BOX,THEN RIGHT CLICK ON TRAY ICON AND SELECT INK FREEZER,AND RESTORE VALUES BACK, OK ON COMPLETION,THEN RESTART YOUR PRINTER AND ALL SERVICE LIGHTS SHOULD BE OFF.
IF YOU HAVE ANY FURTHER ISSUE LET ME KNOW
THANKS
KEVIN
May 05, 2009 | Epson Stylus RX425 Multifunction...
Epson stylus photo rx425 says there's no inkbut there is!
try re-install cartridge and chcek connection on the inks and with pc
Aug 13, 2008 | Epson Stylus RX425 Multifunction...
EPSON STYLUS PHOTO RX425
hi if all the lights are flashing and if you have tried turning printer off and unplugging it from power supply and still you are getting the same error lights then chances are thats a hardware issue already.
call epson support so that they can assist you regarding the warranty status of your printer. Thanks for using Fixya!!
Jun 21, 2008 | Epson Stylus RX425 Multifunction...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
191 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
