Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer keep flashing Ld and beeping
I have a whirlpool cabrio and it keep stoping and flashing Ld and beeping and i dont know what to do about it and i cant find the manual for it.
SOURCE: Won't do anything
LD flashes when the water level does not change after the drain pump is on. Check the following:
Is it oversudsed?
Is the drain pump clogged?
Is the drain hose kinked or clogged?
Is the drain hose installed properly?
Is the drain hose height greater than 96"?
Press PAUSE/CANCEL to clear display.
Posted on Dec 30, 2007
ngfam1
  • 639 Answers
SOURCE: i have a cabrio washer
Friend,
ngfam1 At your service!
When it is a code the machine is telling you that there is a fault and the electronic system needs to be diagnosed by a trained tech.
My advise is,
You spent enough money buying that Cabrio to be experimenting and guessing and buying expensive parts for it!
Let the tech fix it 123 and your done. It may not have needed the drain pump and now that money could have covered the service call!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 30, 2008
tzweeb
  • 318 Answers
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: keep getting LD error code on whirlpool cabrio washer
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Posted on Apr 05, 2009
rickead1
  • 1998 Answers
SOURCE: My whirlpool cabrio he 4.5
Error Code - Ld Problem - Long Drain Solution - When the machine consumes 5 minutes or more to drain out water to where the operating pressure switch resets
Posted on Sep 02, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Flashing Ld on display
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Cabrio Manual
More topslosher failure codes and explanations are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't drain. Keeps flashing LD
LD means long drain time need to pull pump and clear.
If that doent work replace pump
Oct 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LD appears. I cannot shut off unless I unplug it
Long Drain you may have a something in the drain hose or drain pump or damaged drain pump.
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  Press STOP/CANCEL to clear the display.
Sep 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio (WTW6600SW1) drains completely then Ld error!
I have a call with the same problem. Pumps all the water out but still flashes LD. Should be the board, The electronic pressure switch is built in to the board. Make sure the pressure chamber on the back right side is not cloged
Aug 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jan 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer Problem
cabiros dont have a wig wag switch check your drain pump for obstructions to find the right repairman go to www.whirlpool.com under support enter your zip code under find a service tech and they will give you a list of people in your area
Jul 07, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
119 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
