Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Throw rug got caught in rollers and now it wont pick mup were are belts located on hoover windtunnel dual 5
  • 20 Answers
Nylon belt in center of brush underneath . not a hard belt change.
Posted on May 06, 2010
I ran the vacuum over throw rugs and the brush roller just stopped. I can't get the roller to work now... it won't even spin and the "brush" feature is in the ON position.
You've got a broken belt. Most Hoover Vacuums have a spare belt attached to the vacuum itself. Replacement is fairly easy and usually won't require tools. To replace your belt:
  1. Unplug the vacuum
  2. Locate clips on bottom of vacuum-Hoover uses clips that can be opened by hand.
  3. Lift up the plate that encloses the rollers
  4. Remove broken belt
  5. Remove roller from it's compartment
  6. Install replacement belt (hooking it around the motor and roller, using the roller for leverage to stretch out the belt until you have the roller in it's compartment.
  7. Replace cover
  8. Put clips back in place.
Mar 21, 2011 | Hoover U5780-900 Windtunnel Cyclonic...
My hoover windtunnel is not picking anything up all of a sudden. Also the roller underneith is not spinning. I've replaced filters and the attachment part is working fine, just when it's in the upright...
The belt that drives the brush roll has broken. That's why it doesn't pick up and why it doesn't pull itself forwards. Check the User Manual (download from Hoover website if necessary) for information on replacing the belt. Good luck!
Feb 05, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Bottom roller bush does not spin
Sounds as if the v-belt came off the idler arm or you broke the v-belt. Either way, take the 4 screws out of the plate around the roller brush and make certain the belt is there and that it sits on the idler wheel. If you remove the roller brush you'll see the wheel. Pay attention to how the ends of the roller brush go back into the vacuum when inserting it and put the plate back on. Also check the thicker main belt is in place as well, it's to the left of the v-belt.
Also, the roller brush should stop when you put it in the upright position. Next time just stand it upright so the throw rug doesn't get drawn quite so far into the vacuum.
Dec 19, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
HOOVER WINDTUNNEL VACUUM MODEL U6454-900 BELT KEEPS COMING OFF
Have you put on a new belt or just keep using the old one. If you haven't replaced it in the last 6 months, then it has stretched to the point where it won't stay on. Another cause is catching throw rugs, towels or something that gets in there and knocks the belt off.
May 31, 2008 | Hoover Vacuums
Hoover Bagless Windtunnel (tank tyle) selfpropeled head throws belt; 2nd one doing exactly as the first vacumm.very hard to put it back on .can't even get one room done
Is this a new belt? If not, get a new one. Check the brush roll, make sure the ends are turning freely, if not, replace it. If you are catching things like a throw rug and towell or some other thing, this will cause the belt to get knocked off of the motor shaft.
May 25, 2008 | Hoover Vacuums
Need illistrated instructions on replacing belts on my self propelled hoover supreme
The flat belt probably has come off, may need to replace it if it hasn't been replaced in a while. May look ok, but am sure it has stretched.
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Sucked a string up and now the self propel won't work
because you caught up the string, the belt is perhaps broken. turn on and check the roller rotates
Jun 07, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
109 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
